ZANOOB's avatar
ZANOOB
Icon for Cirrus rankCirrus
Jul 23, 2021
iRule not working to have a RADIUS presistant load balancing.
Hello All,
I having trouble with an iRule that I created to load balance the RADIUS traffic on F5. I have a virtual server created that is listening on "all ports" and I have created an iRule in which it will only accept packets with ports 1812 & 1813.
This iRule is called in a Persistent profile I created (where parent profile is Universal). This Persistent profile was called under the Virtual server --resources--> Default Persistent profile.
Somehow this is it is not working for me. I see that the packets are reaching the F5 , but "Access-Request" packets are not being sent out to the pool members. iRule for reference is shown below :
when RULE_INIT {
 array set ::attr_code2name {
         1     User-Name
         2     User-Password
         3     CHAP-Password
         4     NAS-IP-Address
         5     NAS-Port
         6     Service-Type
         7     Framed-Protocol
         8     Framed-IP-Address
         9     Framed-IP-Netmask
        10     Framed-Routing
        11     Filter-Id
        12     Framed-MTU
        13     Framed-Compression
        14     Login-IP-Host
        15     Login-Service
        16     Login-TCP-Port
        17     (unassigned)
        18     Reply-Message
        19     Callback-Number
        20     Callback-Id
        21     (unassigned)
        22     Framed-Route
        23     Framed-IPX-Network
        24     State
        25     Class
        26     Vendor-Specific
        27     Session-Timeout
        28     Idle-Timeout
        29     Termination-Action
        30     Called-Station-Id
        31     Calling-Station-Id
        32     NAS-Identifier
        33     Proxy-State
        34     Login-LAT-Service
        35     Login-LAT-Node
        36     Login-LAT-Group
        37     Framed-AppleTalk-Link
        38     Framed-AppleTalk-Network
        39     Framed-AppleTalk-Zone
        60     CHAP-Challenge
        61     NAS-Port-Type
        62     Port-Limit
        63     Login-LAT-Port
when CLIENT_ACCEPTED {
  if { ([UDP::local_port] != 1812) && ([UDP::local_port] != 1813) } {
   log local0. "packet on port [UDP::local_port] dropped"
   drop
  }else {
      set CALLID [RADIUS::avp 31 string]
      persist uie $CALLID
      log local0. "persisted $CALLID"
when CLIENT_DATA {
   if { [UDP::local_port] == 1813 } {
   set IP [RADIUS::avp 8 ip4]
   if { $IP != "" } {
       table set $IP [LB::server addr] 900
       log local0. "Radius maps $IP to [LB::server addr] for $CALLID"
when LB_SELECTED {
   log local0. "Selected [LB::server addr] [LB::server port]"
when SERVER_DATA {
   persist add uie $CALLID
   log local0. "persist added for $CALLID to [LB::server addr]"
  • Hi ZANOOB,
    [RADIUS::avp 31 string] may be returning empty string. If empty, iRule will throw an error.
    Can you investigate the ltm logs and try this iRule?
    when CLIENT_DATA {
    		if { $IP != "" } {
    		drop
    	elseif {
    		if { $CALLID ne "" } {
    			persist uie $CALLID
    when CLIENT_DATA {
    		if { $IP ne "" && $CALLID ne "" } {
    when LB_SELECTED {
    when SERVER_DATA {
  • Hello Enes Afsin Al,
    Thank you for your reply. Much appreciated.
    The above iRule, I was not able to save it since it shows some syntax errors. Not an expert in scripts, so couldn't find what is wrong with the syntax of it.
    01070151:3: Rule [/Common/CallIDUIE2] error: /Common/CallIDUIE2:17: error: [parse error: PARSE syntax 501 {syntax error in expression "
    log local0. ...": variable references require preceding $}][{
    persist uie $CALLID
    /Common/CallIDUIE2:24: error: [missing a script after "elseif"][]
    /Common/CallIDUIE2:27: error: ["Duplicate event"][when CLIENT_DATA {
    The packet capture shows the AVP 31 attribute ( Calling-Station-Id) in it. So the issue is not the attribute value missing, however, something that F5 is not able to understand is the packet not processing it forwards.
    Frame 2: 317 bytes on wire (2536 bits), 317 bytes captured (2536 bits)
    Ethernet II, Src: Fortinet_09:00:12 (00:09:0f:09:00:12), Dst: VMware_f5:03:01 (00:50:56:f5:03:01)
    802.1Q Virtual LAN, PRI: 0, DEI: 0, ID: 4091
    Internet Protocol Version 4, Src: 172.17.70.60, Dst: 10.1.6.100
    User Datagram Protocol, Src Port: 54892, Dst Port: 1812
    RADIUS Protocol
       Code: Access-Request (1)
       Packet identifier: 0x5e (94)
       Length: 164
       Authenticator: e0a10849518a2fc1f0827505db9f8a5c
       Attribute Value Pairs
           AVP: t=NAS-IP-Address(4) l=6 val=172.17.70.60
           AVP: t=NAS-Port(5) l=6 val=0
           AVP: t=NAS-Port-Type(61) l=6 val=Virtual(5)
           AVP: t=User-Name(1) l=15 val=mgalantowicza
           AVP: t=User-Password(2) l=18 val=Encrypted
           AVP: t=Service-Type(6) l=6 val=Shell-User(6)
           AVP: t=Calling-Station-Id(31) l=14 val=b0b867cd68ee
               Type: 31
               Length: 14
               Calling-Station-Id: b0b867cd68ee
           AVP: t=Called-Station-Id(30) l=14 val=b0b867cd68ee
           AVP: t=Vendor-Specific(26) l=23 vnd=Aruba, a Hewlett Packard Enterprise company(14823)
           AVP: t=Vendor-Specific(26) l=18 vnd=Aruba, a Hewlett Packard Enterprise company(14823)
           AVP: t=Message-Authenticator(80) l=18 val=a0d082620a1137f9110e2a5975c7d6a8
    F5 Ethernet Trailer Protocol
    However, I will check the LTM logs. But last time I checked it really didn't give any error for the virtual server. It simply is not forwarding the traffic, to the load-balanced Radius servers.
