lipos_54863's avatar
lipos_54863
Apr 16, 2010
irule not working on HTTPS
I have a problem.
I need to apply this irule to both HTTP and HTTPS VS.
No persietence is added on the F5s.
It's doing it's thing on HTTP but crushing on HTTPS and showing "The connection was reset".
HTTPS is doing SSL offloading and both are using the same pool. Any suggestion?
timing on
if { [HTTP::uri] contains "SingleSignOn"} {
node 89.x.x.x
log local0. "UNI triggered by: [HTTP::host][HTTP::uri], remote IP: [IP::remote_addr], node IP: [LB::server addr]"
elseif { [HTTP::uri] contains "SSO"} {
node 89.x.x.x
Logs for HTTP are working fine and showing in the syslog, but logs for HTTPS are not showing at all and the the connection is being reset. Any idea?
  • hoolio's avatar
    hoolio
    Hi Lipos,
    I think you need to specify the port in the node command if LTM needs to do port translation for the HTTPS VS. Can you try this:
       switch [HTTP::uri] {
          "SingleSignOn" -
          "SSO" {
              node 89.x.x.x 80
    Aaron
  • Nice!
    All working fine.
    Your iRule looks better, but a question: is "-" after "SingleSignOn" is needed, or is it a typo?
  • hoolio's avatar
    hoolio
    The - in a switch statement means that the next case's action should be taken. It's just a way to group multiple switch cases.
    http://www.tcl.tk/man/tcl8.4/TclCmd/switch.htm
    If a body is specified as - it means that the body for the next pattern should also be used as the body for this pattern (if the next pattern also has a body of - then the body after that is used, and so on). This feature makes it possible to share a single body among several patterns.
    Aaron
