skahler_85363's avatar
skahler_85363
Jun 05, 2008
iRule not always processing
I had emailed support to answer my question and the response back was that this was an iRule question and they seemed to infer I'd be best to ask here first.
I have written a very simple I rule to catch the word gadget in UserAgent string because the service I run get's nailed with badly written Windows Vista gadgets, to the tune of 1.5 million requests per hour. When I placed my servers behind the LTM with this iRule in place I was still seeing about 30,000 requests come through per day that contained gadget in the UserAgent string. It must be working because it's filtering out the lion's share of them and my logs tell me that all the requests are going through the LB and not getting around it some how.
So my question is: In what cases would the logic for an iRule not be applied to request passing through the LB?
  • Here's my iRule
    if { [string match "*gadget*" [HTTP::header Referer] ] } {
    discard
    and a request coming through while it was in place
    172.20.2.106 - - [30/May/2008:00:14:13 -0500] "GET /blah.blah.com/blah.gif HTTP/1.1" 304 0 "x-gadget:///blah.htm" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.0.04506)"
    I apologize as the original post said User-Agent and it's Referer. There are other gadget requests out there I'm looking to block as well as x-gadget and thus the wildcards.
    It's my first iRule so maybe I'm missing something obvious
  • Could it be a case issue? You're matching against "*gadget*", but is it possible something is coming in with "Gadget"?
    If so, you'd want to make the referer lowercase before doing the match.
    Otherwise, I don't see anything bad in your irule (assuming the referer is the only place you'd need to check).
  • I think the following a more simpler iRule:
          if { [HTTP::header "Referer"] contains "gadget" } {
               discard
    This simply means that if you have a referer that contains gadget anywhere in the header field it will discard. For example it was discard "gadget, disgadget, mothergadget, papagadget, gogogadgetchopper, etc" However, I am not sure if it's case sensitive. If it is then it the code could be written as the following:
          if { [string tolower [HTTP::header "Referer"]] contains "gadget" } {
               discard
    Click here if you want to look at HTTP::header function more closely.
    Hope this helps
    CB
  • Thanks I like that rule better as it's a little more clean and readable in my opinion. It's what I'll use I put this back into place.
    It's not a case issue as in my access logs what is passing through matches the same case of iRule, as I'm trying to note in my log string there which is an edited (to protect the innocent ) version of an actual request.
    Another question you may be able to answer for me, is there an advantage to using reject over discard/drop in a application with high connection numbers?
    SK
