Sams_88783's avatar
Sams_88783
Jun 23, 2011
Irule Help
There was a “begins with” clause in version 4.x that we used to route traffic based on the context root of the URL's.
I need to know if the “begins with” has been completely removed or replaced with something else in version 9.x
  • hoolio's avatar
    hoolio
    In v9 and higher, you can use starts_with. But to do multiple URI checks, it would be more efficient to use a switch statement:
    http://devcentral.f5.com/wiki/default.aspx/iRules/operators
    http://devcentral.f5.com/wiki/default.aspx/iRules/starts_with
    http://devcentral.f5.com/wiki/default.aspx/iRules/switch
    Aaron
