cymru81's avatar
cymru81
Sep 03, 2019
irule help based on uri
Hi, ive done some searching on here but cannot find the exact help i need. We have the following scenario, can someone assist with an irule that will achieve this please?
we have one VIP that hostname site.abc.com resolves to, if user visits https://site.abc.com/live it should redirect to pool "pool_live" maintaining the uri "/live". If user visits https://site.abc.com/test it should redirect to pool "pool_test" again maintaining the uri.
how can we achieve this?
thanks in advance!
  • Hi
    You could do something like
    	if {[HTTP::uri] starts_with "/live"}{
    		pool pool_live
    	} elseif {[HTTP::uri] starts_with "/test"}{
    		pool pool_test
    • DanS92's avatar
      DanS92
      Icon for Cirrus rankCirrus
      Another way would be with a Local Traffic Policy instead of an iRule. Under Local Traffic > Policies > Policy List, create a new policy. You'd need a rule in the policy like this for the first request:
      The rule for the second URI would be built the same way. Then apply the policy to the VIP.
    • cymru81's avatar
      cymru81
      Im sorry to move the goalposts but my brief has changed to the following now:
      we have one VIP that hostname site.abc.com resolves to, if user visits https://site.abc.com/live it should redirect to pool "pool_live" changing the ur toi "/live_site". If user visits https://site.abc.com/test it should redirect to pool "pool_test" changing the uri to /test_site.
      Is this achievable?
      • Hi cymru81,
        iRule:
        	if { [string tolower [HTTP::host]] equals "site.abc.com" } {
        		switch -glob [string tolower [HTTP::uri]] {
        			"/live" {
        				HTTP::uri "/live_site"
        				pool pool_live
        			"/test" {
        				HTTP::uri "/test_site"
        				pool pool_test
        iRule with redirect:
        			"/live" {
        				HTTP::redirect "https://site.abc.com/live_site"
        				pool pool_live
        			"/test" {
        				HTTP::redirect "https://site.abc.com/test_site"
        				pool pool_test
         If the HTTP::host is not site.abc.com, you can reject requests.
  • thank you the first rule is just the job!
    ive got another issue now, it works as expected so if a user goes to https://site.abc.com/live they end up at https://site.abc.com/live_site but if they try to navigate any subsequent links it fails.
    Basically we have an external url https://site.abc.com/live_site/ that we want a proxy mapping that will go to http://internalserver:1234/live - we have a pool "pool_live" that contains "internalserver:1234".
    is this totally achievable or am i missing something fundamental!
  • Hi
    To keep the rest of the path in place, use something like this. This will replace /live with /live_site and then remove the first 5 characters from the uri (so /live) and then insert the rest of the path
    		HTTP::uri /live_site[string range [HTTP::uri] 5 end]
    		pool pool_live
    		HTTP::uri /test_site[string range [HTTP::uri] 5 end]
    		pool pool_test
  • thank you once again! ive managed to get this working now with a local traffic policy and a rewrite profile, think some luck involved too!
