bsb's avatar
bsb
7 years ago
irule for specific pools
Team, would like to configure an irule to redirect based on client ip's.
when HTTP_REQUEST { if { [matchclass [IP::client_addr] equals 1.1.1.0/24] } { do nothing. } elseif {([class match [IP::client_addr] equals 2.2.2.0/24]) }{ HTTP::redirect "; } }
It doesn't work, is there a modification required.
  • Hi,
    First of create your DataGroup then use this irule:
    when CLIENT_ACCEPTED {
        if { not ( [class match [IP::client_addr] equals my_ip_dg] ) } {
             do nothing
        } elseif {([class match [IP::client_addr] equals my_ip_dg]) }{
            HTTP::redirect "https://www.test.com"
    Regards
  • oguzy's avatar
    oguzy
    If you do not want to create a data group, you can try the below one:
        if { [IP::addr [IP::client_addr] equals 1.1.1.0/24] } {
             do nothing
        } elseif { [IP::addr [IP::client_addr] equals 2.2.2.0/24] } {
            HTTP::redirect "https://www.test.com";
    • bsb's avatar
      bsb
      Missed one part, LTM is behind proxy which hides the incoming client ip, tried below option, still didn't work.
      i am trying to access the site from 2.2.2.x network and instead of redirect, posting a custom message
      when HTTP_REQUEST { HTTP::header insert X-Forwarded-For [IP::remote_addr] if { [IP::addr [IP::client_addr] equals 1.1.1.0/24] } { do nothing } elseif { [IP::addr [IP::remote_addr] equals 2.2.2.0/24] } { HTTP::respond 503 content {
    • bsb's avatar
      bsb
      below content were removed.
      < html> < head>< title> regret message < /title>< /head> < /html>
    • oguzy's avatar
      oguzy
          HTTP::header insert X-Forwarded-For [IP::client_addr]
          if { [IP::addr [HTTP::header X-Forwarded-For] equals 1.1.1.0/24] } {
               do nothing
          } elseif { [IP::addr [HTTP::header X-Forwarded-For] equals 2.2.2.0/24] } {
               HTTP::respond 503 content "Page is currently unavailable."
               event disable
               TCP::close
      If it does not work again, please share any errors if exist in the /var/log/ltm or try to logging for debug.
  • Hi,
             do nothing
    • bsb's avatar
      bsb
    • bsb's avatar
      bsb
    • oguzy_191375's avatar
      oguzy_191375
               do nothing
               event disable
               TCP::close
