Aditya_Mehra's avatar
Feb 22, 2019
iRule for redirection for ssl and non ssl on same port
Hi All, I have Virtual Server on a port 1500. The SSL terminates here as well.
I need help in a iRule to send traffic to different pools for ssl and non ssl traffic. SSL request on port 1500 goes to pool 1
Non ssl request on 1500 port goes to pool 2
Thanks, Aditya
  • So do you have two different virtual servers, one on 1500 and one on 1550? Just use a default pool for each of those.
    If you have only a virtual server on port 1500, just create a second virtual server on 1550 and have it go to the other pool. No iRule needed.
  • Hi Aditya,
    It is doable, lets say below is your requirement,
    • VIP is 1.1.1.1:1500
    • Pool1 servers are non-ssl servers
    • Pool2 servers are ssl servers
    • You want http & https to work on 1.1.1.1:1500 VIP.
    • http traffic to goto Pool1
    • https traffic to goto Pool2
    1st, you have to create a clientssl profile which would accept both ssl and non-ssl traffic.
    tmsh create ltm profile client-ssl  allow-non-ssl enabled
    2nd, you have to create the irule,
    ltm rule ssl-and-nonssl-irule {
    when CLIENT_ACCEPTED {
    set https_state 0
    log local0. "Lets set https_state value to as 0, meaning its a HTTP traffic"
    when CLIENTSSL_HANDSHAKE {
    set https_state 1
    log local0. "Lets set https_state value to as 1, meaning its a HTTPS traffic"
    if { $https_state == 0 } {
    pool pool_1
    log local0. "https_state value is 0, meaning its a HTTP traffic & HTTP Pool will be selected"
    pool pool_2
    log local0. "https_state value is 1, meaning its a HTTPS traffic & HTTPS Pool will be selected"
    when SERVER_CONNECTED {
    if { $https_state == 0} {
    log local0. "https_state value is 0, meaning its a HTTP traffic & forcing serverside SSL should not be selected"
    SSL::disable serverside
    log local0. "pool_1 connected"
    } elseif {$https_state == 1} {
    log local0. "https_state value is 1, meaning its a HTTPS traffic & serverside SSL would be selected"
    log local0. "pool_2 connected"
    Finally have the custom-clientssl & serverssl profiles added to your VS. Add the Irule too. It would be something like below,
    ltm virtual test-ssl-nonssl {
        destination 1.1.1.1:1500
        ip-protocol tcp
        mask 255.255.255.255
        profiles {
            http { }
            custom-clientsslprofile-name {
                context clientside
            serverssl {
                context serverside
            tcp { }
        rules {
        source 0.0.0.0/0
        source-address-translation {
            pool xxxx
            type snat
        translate-address enabled
        translate-port enabled
        vs-index 123
    Let me know how it goes.
