Royal_131741's avatar
Royal_131741
Aug 16, 2013
iRule for port forwarding ssh to port 2222 on Pool
hope anybody can help 🙂
I have two LBs (activ/activ) and two Server in the Pool called RealSERVER, which are load balanced with lc.
On the two Real Server i have two sshd, which are listening to Port 22 and Port 2222.
The sshd (on both machines), which is listening to Port 2222 has the same rsa/dsa key, because i don't want a conflict, if the client wants to connect to the VIP.
If the Client wants to connect to the VIP via SSH, it would be great, if the LBs redirect traffic from 22 to Port 2222.
I've tested two iRules but both didn't work:
when CLIENT_ACCEPTED {
if { [TCP::local_port] == 22 } {
pool RealServer 2222
and
switch [TCP::local_port 22] {
2222 { pool RealSERVER}
default { discard }
If i use this iRule:
node 192.xxx.xxx.xxx 2222  IP RS1
node 192.xxx.xxx.xxx 2222  IP RS2
the connection will be redirect from 22 to 2222 but the load balance didn't work. Every time I connect via ssh to the VIP, i'm on RS1. If i open a second terminal i'm also connected to RS1.
  • BinaryCanary_19's avatar
    BinaryCanary_19
    Historic F5 Account
    I think you should not need an irule here. One of your servers is listening on port 22, the other is on port 2222. You can have a pool where one member is on port 22 and the other member is on port 2222.
    A standard vip should be able to loadbalance to these servers and correct the ports as needed...
    • hoolio's avatar
      hoolio
      Agreed. I'd use a FastL4 VS as there's nothing to do at L7 for SSH traffic.
  • Thx for the fast reply and the good idea,
    but i would like to know the port forwarding rule. i think it's better to know different ways to the goal ;-)
    i have already three virtual servers on both LBs (ssh, http, ftp) and just one pool. i wouldn't like to add another server...
  • As AFanen said you can achieve this using standard LTM config. but you can also achieve using an irule you were pretty much there with your first one. If you want to load balance across your pool using 2222 need to create a pool using members using 2222, otherwise you can specifically specify individual pool members and ports. also I think you'll need to consider persistence since you are using SSH. Here's some code that may help.
            log "ssh_server_pool with members 192.168.101.11:2222 192.168.101.12:2222 - using source address persistence"
            necessary if not configured in the virtual server configuration - translate address from VIP to member - translate port from 22 to 2222.
            translate address enable
            translate port enable
            load balance across pool
            pool ssh_server_pool
            as we're talking ssh we need to set a persistence profile
            persist source_addr 255.255.255.255 0
            log the localport
            log "localport: [TCP::local_port] "
        when SERVER_CONNECTED {
            just for logging/debugging
        log "serverport: [TCP::server_port] "
    cont...
  • The LTM config (I used a IP forwarding VS to listen on the VIP as the irule specifies the pool and a pool configured with members using port 2222 - seems like F5 recognises 2222 as rockwell-csp2 😞
        ltm pool ssh_server_pool {
        description "2222 backend port"
        members {
            DNS1:rockwell-csp2 {
                address 192.168.101.11
            DNS2:rockwell-csp2 {
                address 192.168.101.12
    ltm virtual ssh_test {
        description ssh_test
        destination 86.189.0.240:any
        ip-forward
        ip-protocol tcp
        mask 255.255.255.255
        profiles {
            fastL4 { }
        rules {
            ssh_test
        source 0.0.0.0/0
        translate-address disabled
        translate-port disabled
        vs-index 11
    log and connection entries:
    (cfg-sync Changes Pending)(Active)(/Common)(tmos.ltm) show /sys conn cs-client-addr 10.12.13.3
        Sys::Connections
        10.12.13.3:56841  86.189.0.240:22  10.12.13.3:56841  192.168.101.11:2222  tcp  3  (tmm: 1)  none
    Aug 16 11:47:06 bnvf5wl001 info tmm[11396]: 01220002:6: Rule /Common/ssh_test : ssh_server_pool with members 192.168.101.11:2222 192.168.101.12:2222 - using source address persistence
    Aug 16 11:47:06 bnvf5wl001 info tmm[11396]: 01220002:6: Rule /Common/ssh_test : localport: 22
    Aug 16 11:47:06 bnvf5wl001 info tmm[11396]: 01220002:6: Rule /Common/ssh_test : serverport: 2222
    Hope it helps, Adrian.
  • Does it work.  I have the same issue:
    I got the following
    ssh_exchange_identification: read: Connection reset by peer
    when -vvv
    OpenSSH_7.2p2 Ubuntu-4ubuntu2.8, OpenSSL 1.0.2g  1 Mar 2016
    debug1: Reading configuration data /root/.ssh/config
    debug3: kex names ok: [diffie-hellman-group1-sha1]
    debug1: Reading configuration data /etc/ssh/ssh_config
    debug1: /etc/ssh/ssh_config line 19: Applying options for *
    debug2: resolving "x.x.x.x" port 22
    debug2: ssh_connect_direct: needpriv 0
    debug1: Connecting to x.x.x.x [x.x.x.x] port 22.
    debug1: Connection established.
    debug1: permanently_set_uid: 0/0
    debug1: key_load_public: No such file or directory
    debug1: identity file /root/.ssh/id_rsa type -1
    debug1: identity file /root/.ssh/id_rsa-cert type -1
    debug1: identity file /root/.ssh/id_dsa type -1
    debug1: identity file /root/.ssh/id_dsa-cert type -1
    debug1: identity file /root/.ssh/id_ecdsa type -1
    debug1: identity file /root/.ssh/id_ecdsa-cert type -1
    debug1: identity file /root/.ssh/id_ed25519 type -1
    debug1: identity file /root/.ssh/id_ed25519-cert type -1
    debug1: Enabling compatibility mode for protocol 2.0
    write: Connection reset by peer
