katic_13597's avatar
katic_13597
Jun 05, 2007
IRULE for Cookie Less Routing for Nokia Phone ?
We have below URL which will be accessed by using Browser in Nokia Phone , All Nokia N-70 Mobile browsers are Cookie less browsers  , we have to maintain the Persistence based on the below URL
https://XX.Xcom/MobileWeb/(X(1)S(y5i41045sammeu45cxvuej45))/login.aspx?ReturnUrl=%2fmobileweb%2fdefault.aspx&AspxAutoDetectCookieSupport=1
in every URL session “(X(1)S(“ these characters are common
I have written below IRULE but it is not working
set m3persist [findstr [HTTP::uri] "(X(1)S(" 24 ";"]
if { $m3persist != "" } {
persist uie $m3persist
pool XX_80
Help will be appreciated.
Kartheek
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    The findstr command looks appropriate, except possibly for the terminator of ";", which doesn't appear in your URI (that I could see, anyway). When you say the rule isn't working, what do you mean? Have you added some logging to see where the logic is breaking down?
    Colin
