abhinay's avatar
abhinay
Dec 22, 2022
iRule for blocking specific traffic for HTTP POST
Hi Everyone, I need some help in setting up an iRule for below requirement.
Need to get 403 Forbidden for below
(method = POST) AND (URI contains /cs OR llisapi.dll) AND (body contains func=qds.) AND (body contains _REQUEST=SYNDICATION_REQUEST)
Below is the Postman body that I am testing
"body": {
"mode": "formdata",
"formdata": [
"key": "func",
"value": "qds.ObjAction",
"type": "default"
"key": "_REQUEST",
"value": "SYNDICATION_REQUEST",
"type": "default"
"key": "qdsRequest",
"value": "A<1,?,'objAction'='create2','subtype'=145,'versionFile_filename'='C:\\windows\\win.ini','func'='',\n'ParentID'=2004,'objType'=145,'name'='qds-createpoc.\ntxt','comment'='created','mimeType'='text/html','textfield'='foobar','CTT_ID'='2004','multiC\nlass'=0,'InheritRequired'=0,'CREATE_Required'=1,'CREATE_Edited'=0,'CREATE_CacheID'=0,'CREATE_Ver\nNum'=1,'versionFile_filelength'='5'>",
"type": "default"
Thank you
  • Hi abhinay,
    you may use the iRule below as a starting point...
    when HTTP_REQUEST  {
    	if { [HTTP::method] eq "POST" } then {
    		switch -glob -- [string tolower [HTTP::path]] {
    			"*/cs*" -
    			"*llisapi.dll*" {
    				if { [HTTP::header value "Content-Lenght"] == 0 } then {
    					# Zero post data...
    				} elseif { ( [string is digit [HTTP::header value "Content-Lenght"]] == 1 )
    					   and ( [HTTP::header value "Content-Lenght"] >= 0 )
    					   and ( [HTTP::header value "Content-Lenght"] <= 1048576 )  } then {
    					HTTP::collect [HTTP::header value "Content-Lenght"]
    				} else { [HTTP::header value "Transfer-Encoding"] eq "chunked" } then {
    					# Someone may have used chunked tranfer encoding... :-(
    					# lets hope we will find the signature on first chunk of received data.
    					HTTP::collect 1
    when HTTP_REQUEST_DATA {
    	# Format tolower, removing any tabs, spaces and line breaks before comparsion
    	set cleaned_payload [string tolower [string map { "	" "" " " "" "\n" "" } [HTTP::payload]]]
    	if { ( [string match {*"key":"_request"*} $cleaned_payload] )
    	 and ( [string match {*"value":"syndication_request"*} $cleaned_payload]) } then {
    		HTTP::respond 403 content "Forbidden" "Content-Type" "text/html"
    	# Alternative if "key" is always preceding "value"
    	# if { [string match {*"key":"_request","value":"syndication_request"*} $string_map] } then {
    	#	HTTP::respond 403 content "Forbidden" "Content-Type" "text/html"
     Cheers, Kai
