irule based pool selection *and* priority group activation?
Hello!
I am using an irule using a switch command with a single virtual server in LTM 11.3 to split traffic between several pools for the same set of hosts.
http://www.abc.com/site2
http://www.abc.com/site3
site1-pool, site2-pool, and site3-pool are all identical. Each has 5 members at priority 2, and 5 members at priority 1, with activation set at less than 1.
The virtual server has no default pool, it has an irule as follows:
switch --glob -- [string tolower [HTTP::path]] {
"/site2*" {
pool site2-pool
return
"/site3*" {
pool site3-pool
return
default {
pool site1-pool
return
Functionally, all traffic is indeed getting sent to each pool correctly. My problem is that pool member priorities are not being respected. Traffic is getting sent to priority 1 members of each pool, even though all of the priority 2 members are up. My other "normal" virtual servers with a single pool correctly send traffic only to the priority 2 servers, it is just the one where the pool is being selected by the iRule that is not respecting the priority.
Am I missing something? Is there something I need to specify in the iRule to cause it to respect the priority group activation settings on the pool to which the traffic is being sent? Or do I have to (ugh) reinvent the priority group activation logic within this irule itself?
- nitass
Employee
this is mine.root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.20.16:80 ip-protocol tcp mask 255.255.255.255 profiles { http { } tcp { } } rules { myrule } source 0.0.0.0/0 source-address-translation { type automap } vlans-disabled } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule ltm rule myrule { when HTTP_REQUEST { pool foo } when HTTP_RESPONSE { log local0. "client [IP::client_addr]:[TCP::client_port] server [IP::server_addr]:[TCP::server_port]" } } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 priority-group 2 session monitor-enabled state up } 200.200.200.111:80 { address 200.200.200.111 priority-group 1 session monitor-enabled state up } } min-active-members 1 monitor gateway_icmp } test [root@ve11a:Active:Changes Pending] config tail -f /var/log/ltm Apr 23 13:07:06 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34211 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34212 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34213 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34214 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34215 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34216 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34217 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34218 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34219 server 200.200.200.101:80 Apr 23 13:07:06 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34220 server 200.200.200.101:80 - nitass
Employee
this is when not using priority group. is there anything i missed?root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 priority-group 2 session monitor-enabled state up } 200.200.200.111:80 { address 200.200.200.111 priority-group 1 session monitor-enabled state up } } monitor gateway_icmp } [root@ve11a:Active:Changes Pending] config tail -f /var/log/ltm Apr 23 13:09:07 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34231 server 200.200.200.101:80 Apr 23 13:09:07 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34232 server 200.200.200.101:80 Apr 23 13:09:07 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34233 server 200.200.200.111:80 Apr 23 13:09:07 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34234 server 200.200.200.111:80 Apr 23 13:09:07 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34235 server 200.200.200.101:80 Apr 23 13:09:07 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34236 server 200.200.200.101:80 Apr 23 13:09:07 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34237 server 200.200.200.111:80 Apr 23 13:09:07 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34238 server 200.200.200.111:80 Apr 23 13:09:07 ve11a info tmm1[8163]: Rule /Common/myrule : client 172.28.19.251:34239 server 200.200.200.101:80 Apr 23 13:09:07 ve11a info tmm[8163]: Rule /Common/myrule : client 172.28.19.251:34240 server 200.200.200.101:80 - Brady_11518
Boy, that sure makes it seem like it should be working as expected.
My VS also has the following characteristics:
lb: observed (node)
tcp (default settings)
tcp-wan-optimized (client, default settings)
tcp-lan-optimized (server, default settings)
http (default settings)
oneconnect (default settings)
wan-optimized-compression (default settings)
webacceleration (default settings)
I'll try removing everything but http and tcp tomorrow, and go to a member based lb on the pools and see if that fixes it.
If one of this seems like it would obviously be the culprit, let me know!
Thanks! - Brady_11518
lb: observed (node)
lb: observed (node)
webacceleration (default settings)I'll try removing everything but http and tcp tomorrow, and go to a member based lb on the pools and see if that fixes it.
Thanks!
- Brady_11518
Ugh. My apologies for the triple reply.
