jt_47643's avatar
jt_47643
Mar 04, 2008
irule appears to be matching on more than expected
What we are trying to do:
We wish to block a portion of our web site from anyone not coming from a particular IP.
This is the code we thought would work:
if (client_addr != 172.20.49.100 and http_uri starts_with "/cn/")
{ redirect to "http://qa-rev-wlc.combinenet.com" }
else
{ use pool qa-rev-wlc }
What we think we are seeing blocked:
URIs like: /company/images/CN_Upper_Logo.png
possibly matching on the /CN portion of the URI.
We are running 4.5.14
Thanks for the help,
Jt
  • hoolio's avatar
    hoolio
    Could the problem be that the client IP address isn't what you're expecting?
    If you send a request for http://example.com/company/images/CN_Upper_Logo.png, do you get redirected? If so, I'd be surprised--I thought the starts_with operator did a string comparison and that it was case sensitive. If that's really happening, can you try escaping the forward slashes with backslashes?
    if (client_addr != 172.20.49.100 and http_uri starts_with "\/cn\/")
    Aaron
