Heinen_Markus's avatar
Heinen_Markus
Aug 01, 2011
iRule and Firefox Problems
Hi
i have a problem with this irule and Firefox Browser with IE it works good
Spezial this part don´t work
"/appserver/*" {
pool DMZ-APP
persist cookie insert APPLSID $APPZeit
log local0. "APPL Client: [IP::remote_addr] VIP: [IP::local_addr] [LB::server]"}
Can someon help me please ?
the complett rule are
set path [string tolower [HTTP::path]]
set APPZeit 7200
switch -glob $path {
"/basicgate/appserver/ws/rubin*" {
pool DMZ-Rubin-APP
persist cookie insert APPLSID $APPZeit}
"/appserver/ws/rubin*" {
pool DMZ-Rubin-APP
log local0. "Rubin: [IP::remote_addr]"}
"/appserver/ws*" {
pool DMZ-LO-APP
"/basicgate/appserver/ws*" {
pool DMZ-LO-APP
"/basicgate/appserver*" {
pool DMZ-APP
"/appserver/*" {
pool DMZ-APP
"/aspnet_client*" {
pool DMZ-APP
default { pool DMZ-CMS
persist cookie insert CMSSID 3600}
  • Hi Heinen,
    What about that piece of code that doesn't work? However, I do find [LB::server] a tad suspicious.
    Bhattman
  • [LB::server] is not useful/valid in the HTTP_REQUEST event since the server pool member selection logic has not yet executed in the event sequence. Not sure what you are trying to obtain by using it. Try removing it. You can also look at the /var/log/ltm log for possible Tcl run time errors.
  • hoolio's avatar
    hoolio
    LB::server should just log the most recently selected pool name:
    http://devcentral.f5.com/wiki/iRules.lb__server.ashx
    LB::server returns a Tcl list with pool, node addr and port. If no server was selected yet or all servers are down, returns default pool name only.
    Heinen, what actually breaks when you test with Firefox? Can you use HttpFox or Fiddler to record the session and see more exactly what's failing?
    Do you have a OneConnect profile enabled on the virtual server? This is necessary for evaluating each HTTP request on a keepalive connection. See this article for details:
    http://devcentral.f5.com/wiki/AdvDesignConfig.ONECONNECT.ashx
    Aaron
