TMcGov_92811
Jul 03, 2012iRule - Using client source tcp port to forward to specific pool
Hello,
I'm looking to write an iRule and apply it to a wildcard virtual server listening on all ports. It would identify the client's source tcp port, and based on that, it would forward traffic to a certain pool.
Thanks, Tom
- Richard__HarlanHistoric F5 AccountWhat I would do is do a class lookup based on the port and lookup the pool, then foward that traffic to the pool found in the class path. Question are you sure about client source port since most client pick a port at random or do you mean the dest port?
- TMcGov_92811
Correct - Brain freeze....
Here is what I mean: Looking to write an iRule and apply it to a wildcard virtual server listening on all ports. It would identify the selected destination tcp port, and based on that, it would forward traffic to a certain pool. - santosh_81454
You can refer these links for tcp port:
https://devcentral.f5.com/wiki/iRules.tcp__local_port.ashx
https://devcentral.f5.com/wiki/iRules.TCP__remote_port.ashx - TMcGov_92811
I found a god way to accomplish this:
when CLIENT_ACCEPTED {
switch [TCP::local_port] {
9951 { pool pool.xa_app_msgapps_9951}
9971 { pool pool.xa_app_msgapps2_9971}
default { discard }
