rajesh1's avatar
rajesh1
Apr 27, 2010
IRULE - HTTP REDIRECT
I am new to Irules and i want someone to validate the my irule based on the following requirement.
we are having a website - www.example.com.au and www.example.co.nz sharing the same virtual ip address and the requirement is to redirect the HTTP request to the remote site if there are no active members in the local pool
www.example.com.au will be redirected to www2.example.co.au - if no active pool members
www.example.co.nz will be redirected to www2.example.co.nz - if no active pool members
Please check the syntax and logic and correct me if i am missing anything
if { [active_members POOL-WEB] == 0 } {
if { [HTTP::host] contains "example.com.au" } {
HTTP::redirect https://www2.example.com.au[HTTP::uri] }
elseif { [HTTP::host] contains "example.co.nz" } {
HTTP::redirect https://www2.example.co.nz[HTTP::uri] }
else { pool POOL-WEB
Raj
  • Hello Raj,
    this iRule is valid in terms of syntax. Have you been able to test it yet? If it doesn't appear to be working check the ltm logs for any errors.
    I'd definately recommend downloading the iRule Editor, it makes writing and checking iRules alot easier.
    Thanks.
