iRule - Down node using Response Header
My dev team and I would like to create an iRule that would look at a value in the response header in order to mark a node (in a pool) up or down. They'll use this for maintenance. Basically they'l be setting a value of "out" in a header named "x-node". I'll probably work to write that to the log as well so that during troubleshooting, I'll know why a node was marked down.
I'm very new to iRules but trying to learn. I have googled and searched for basic iRules, the use of curl, and I cant seem to get pointed in the right direction.
Thanks in advance.
Jim
Have you considered doing this in an HTTP monitor?
ltm monitor http HTTP-Down_on_responce_header { defaults-from http destination *:http interval 5 ip-dscp 0 recv "x-node: up" recv-disable "x-node: down" send "GET /\r\n" time-until-up 0 timeout 16 }- Jim_Couch_16225
I first tried that, but it doesnt seem to work. My "get" is in a different path. Wondering if that is why its failing. On my get string I have "/logging/loggingservice.asmx \r\n"
