IPSEC Affinity Not Working
I have an HA LTM in load balancing Cisco DMVPN connections to four hub routers 10.20.1.101, 2, 3, & 4. Problem is that it's load balancing the ISAKMP and ESP to different hub routers, as you can see from the connection table. What's the simplest way to get the ISAKMP/ESP from the public source address (left) to the same hub router (right)? I have a simple configuration with a vip, one pool with four members and no snat, let me know if you need to see more. THANKS!! [root@etc-rslb-dmvpn-1:Active:Changes Pending] config tmsh show sys connection | grep 172.16.1.10: 99.126.100.55:500 172.16.1.10:500 99.126.100.55:61936 10.20.1.104:500 udp 5 (tmm: 1) 99.108.26.170:500 172.16.1.10:500 99.108.26.170:500 10.20.1.101:500 udp 5 (tmm: 3) 99.126.100.55:4500 172.16.1.10:4500 99.126.100.55:35306 10.20.1.103:4500 udp 4 (tmm: 1) 99.108.26.170:4500 172.16.1.10:4500 99.108.26.170:50000 10.20.1.103:4500 udp 4 (tmm: 3) 108.86.114.132:4500 172.16.1.10:4500 108.86.114.132:23287 10.20.1.104:4500 udp 0 (tmm: 3)
- What_Lies_Bene1
Any persistence setup? If so what? If not, that would be a great start.
- KernelPanic
Yes, I was using soure address persistence, but instead of using the client source address the LTM was using the VIP address. I changed to destination address and connections all go to the same router, which is not what I want either.
- What_Lies_Bene1
OK. Can you go back to Source Address persistence (which should be based on the source IP as it arrives at the LTM) and also select the Match Across Services option so it'll take into account traffic received on different ports.
- What_Lies_Bene1
Hmmm. Well that really should work. Any NAT occuring, not that it should matter.
Can you get another output from the connection table please and post it here properly formatted. I can't quite work out what's what from the first one you posted. Thanks
- KernelPanic
Sure, There is NAT, but no SNAT. 172.16.1.10 is the VIP address. 10.20.1.103 is the pool member. I dont understand why it is basing persistence on the VIP address. I also removed persistence mirroring but I think that has more to do with HA.
Sorry about the messy post before, I'm not sure how to format this. I tried the backtic but it took all of the \n out. Here goes.. BTW thanks for your fast response!
Sys::Persistent Connections source-address 172.16.1.10:any 10.20.1.103:any 3 Total records returned: 1 config tmsh show sys connection | grep 172.16.1.10:99.126.100.55:500 172.16.1.10:500 99.126.100.55:16279 10.20.1.103:500 udp 9 (tmm: 1)99.108.26.170:500 172.16.1.10:500 99.108.26.170:39835 10.20.1.103:500 udp 5 (tmm: 3)99.126.100.55:4500 172.16.1.10:4500 99.126.100.55:4500 10.20.1.101:4500 udp 8 (tmm: 1)99.108.26.170:4500 172.16.1.10:4500 99.108.26.170:4500 10.20.1.101:4500 udp 5 (tmm: 3)99.88.254.242:500 172.16.1.10:500 99.88.254.242:79 10.20.1.103:500 udp 6 (tmm: 0)108.86.114.132:4500 172.16.1.10:4500 108.86.114.132:51339 10.20.1.103:4500 udp 0 (tmm: 3)99.88.254.242:4500 172.16.1.10:4500 99.88.254.242:4500 10.20.1.101:4500 udp 5
connectionSys::Connections10.20.0.9:37128 10.20.1.104:8 10.20.0.9:24195 10.20.1.104:8 icmp 1 (tmm: 0)10.20.0.9:45498 10.20.1.102:8 10.20.0.9:45498 10.20.1.102:8 icmp 5 (tmm: 2)10.20.0.9:65288 10.20.1.101:8 10.20.0.9:60298 10.20.1.101:8 icmp 10 (tmm: 0)10.20.0.9:47519 10.20.1.102:8 10.20.0.9:47519 10.20.1.102:8 icmp 0 (tmm: 3)10.20.0.9:24889 10.20.1.101:8 10.20.0.9:42103 10.20.1.101:8 icmp 7 (tmm: 1)10.20.0.9:38264 10.20.1.104:8 10.20.0.9:20805 10.20.1.104:8 icmp 3 (tmm: 0)99.126.100.55:500 172.16.1.10:500 99.126.100.55:16279 10.20.1.103:500 udp 16 (tmm: 1)10.20.0.9:29007 10.20.1.101:8 10.20.0.9:40193 10.20.1.101:8 icmp 2 (tmm: 3)10.20.0.9:60195 10.20.1.104:8 10.20.0.9:60195 10.20.1.104:8 icmp 11 (tmm: 3)99.108.26.170:500 172.16.1.10:500 99.108.26.170:39835 10.20.1.103:500 udp 12 (tmm: 3)10.20.0.9:7989 10.20.1.101:8 10.20.0.9:42872 10.20.1.101:8 icmp 1 (tmm: 1)99.126.100.55:4500 172.16.1.10:4500 99.126.100.55:4500 10.20.1.101:4500 udp 16 (tmm: 1)10.20.0.9:16245 10.20.1.103:8 10.20.0.9:56063 10.20.1.103:8 icmp 9 (tmm: 1)10.20.0.9:28045 10.20.1.104:8 10.20.0.9:14646 10.20.1.104:8 icmp 7 (tmm: 1)99.108.26.170:4500 172.16.1.10:4500 99.108.26.170:4500 10.20.1.101:4500 udp 13 (tmm: 3)10.20.0.9:14082 10.20.1.103:8 10.20.0.9:9736 10.20.1.103:8 icmp 14 (tmm: 2)10.20.0.9:46868 10.20.1.103:8 10.20.0.9:7838 10.20.1.103:8 icmp 4 (tmm: 0)10.20.0.9:13278 10.20.1.103:8 10.20.0.9:13278 10.20.1.103:8 icmp 10 (tmm: 2)10.20.0.9:50581 10.20.1.102:8 10.20.0.9:50581 10.20.1.102:8 icmp 9 (tmm: 1)99.88.254.242:500 172.16.1.10:500 99.88.254.242:79 10.20.1.103:500 udp 4 (tmm: 0)10.20.0.9:30984 10.20.1.103:8 10.20.0.9:11335 10.20.1.103:8 icmp 5 (tmm: 0)108.86.114.132:4500 172.16.1.10:4500 108.86.114.132:51339 10.20.1.103:4500 udp 0 (tmm: 3)10.20.0.9:33176 10.20.1.101:8 10.20.0.9:33176 10.20.1.101:8 icmp 6 (tmm: 0)10.20.0.9:39349 10.20.1.102:8 10.20.0.9:9783 10.20.1.102:8 icmp 4 (tmm: 1)99.88.254.242:4500 172.16.1.10:4500 99.88.254.242:4500 10.20.1.101:4500 udp 3 (tmm: 0)10.20.0.9:21928 10.20.1.104:8 10.20.0.9:21928 10.20.1.104:8 icmp 9 (tmm: 0)10.20.0.9:51093 10.20.1.102:8 10.20.0.9:1810 10.20.1.102:8 icmp 11 (tmm: 1)Total - What_Lies_Bene1
Still a bit hard to read I'm afraid. I normally use the button with a vertical bar of grey on it's left after selecting the relevant text but sometimes I do have to do it twice. What type of VS is this, a standard one? If so, I'd certainly suggest switching to Performance (layer 4).
- KernelPanic
It's a 2000 platform, FastL4 is enabled. trying backtic this time
show sys version Sys::Version Main Package Product BIG-IP Version 11.2.1 Build 862.0 Edition Hotfix HF2 Date Wed Nov 21 13:47:12 PST 2012 Hotfix List ID402164 ID400381 ID396072 ID400789 ID404036 ID397435 ID405422 ID399661 ID362739 ID405254 ID397836 ID395272 ID400775 ID398974 ID397882 ID404433 ID404235 ID405415 ID403052 ID397981 ID404037Sys::Version Main Package Product BIG-IP Version 11.2.1 Build 862.0 Edition Hotfix HF2 Date Wed Nov 21 13:47:12 PST 2012
Hotfix List ID402164 ID400381 ID396072 ID400789 ID404036 ID397435 ID405422 ID399661 ID362739 ID405254 ID397836 ID395272 ID400775 ID398974 ID397882 ID404433 ID404235 ID405415 ID403052 ID397981 ID404037 `
- KernelPanic
config tmsh show sys connection | grep 172.16.1.10: 99.126.100.55:500 172.16.1.10:500 99.126.100.55:16279 10.20.1.103:500 udp 9 (tmm: 1) 99.108.26.170:500 172.16.1.10:500 99.108.26.170:39835 10.20.1.103:500 udp 5 (tmm: 3) 99.126.100.55:4500 172.16.1.10:4500 99.126.100.55:4500 10.20.1.101:4500 udp 8 (tmm: 1) 99.108.26.170:4500 172.16.1.10:4500 99.108.26.170:4500 10.20.1.101:4500 udp 5 (tmm: 3) 99.88.254.242:500 172.16.1.10:500 99.88.254.242:79 10.20.1.103:500 udp 6 (tmm: 0) 108.86.114.132:4500 172.16.1.10:4500 108.86.114.132:51339 10.20.1.103:4500 udp 0 (tmm: 3) 99.88.254.242:4500 172.16.1.10:4500 99.88.254.242:4500 10.20.1.101:4500 udp 5 (tmm: 0) [root@etc-rslb-dmvpn-1:Active:Changes Pending] config tmsh show sys connection Sys::Connections 10.20.0.9:37128 10.20.1.104:8 10.20.0.9:24195 10.20.1.104:8 icmp 1 (tmm: 0) 10.20.0.9:45498 10.20.1.102:8 10.20.0.9:45498 10.20.1.102:8 icmp 5 (tmm: 2) 10.20.0.9:65288 10.20.1.101:8 10.20.0.9:60298 10.20.1.101:8 icmp 10 (tmm: 0) 10.20.0.9:47519 10.20.1.102:8 10.20.0.9:47519 10.20.1.102:8 icmp 0 (tmm: 3) 10.20.0.9:24889 10.20.1.101:8 10.20.0.9:42103 10.20.1.101:8 icmp 7 (tmm: 1) 10.20.0.9:38264 10.20.1.104:8 10.20.0.9:20805 10.20.1.104:8 icmp 3 (tmm: 0) 99.126.100.55:500 172.16.1.10:500 99.126.100.55:16279 10.20.1.103:500 udp 16 (tmm: 1) 10.20.0.9:29007 10.20.1.101:8 10.20.0.9:40193 10.20.1.101:8 icmp 2 (tmm: 3) 10.20.0.9:60195 10.20.1.104:8 10.20.0.9:60195 10.20.1.104:8 icmp 11 (tmm: 3) 99.108.26.170:500 172.16.1.10:500 99.108.26.170:39835 10.20.1.103:500 udp 12 (tmm: 3) 10.20.0.9:7989 10.20.1.101:8 10.20.0.9:42872 10.20.1.101:8 icmp 1 (tmm: 1) 99.126.100.55:4500 172.16.1.10:4500 99.126.100.55:4500 10.20.1.101:4500 udp 16 (tmm: 1) 10.20.0.9:16245 10.20.1.103:8 10.20.0.9:56063 10.20.1.103:8 icmp 9 (tmm: 1) 10.20.0.9:28045 10.20.1.104:8 10.20.0.9:14646 10.20.1.104:8 icmp 7 (tmm: 1) 99.108.26.170:4500 172.16.1.10:4500 99.108.26.170:4500 10.20.1.101:4500 udp 13 (tmm: 3) 10.20.0.9:14082 10.20.1.103:8 10.20.0.9:9736 10.20.1.103:8 icmp 14 (tmm: 2) 10.20.0.9:46868 10.20.1.103:8 10.20.0.9:7838 10.20.1.103:8 icmp 4 (tmm: 0) 10.20.0.9:13278 10.20.1.103:8 10.20.0.9:13278 10.20.1.103:8 icmp 10 (tmm: 2) 10.20.0.9:50581 10.20.1.102:8 10.20.0.9:50581 10.20.1.102:8 icmp 9 (tmm: 1) 99.88.254.242:500 172.16.1.10:500 99.88.254.242:79 10.20.1.103:500 udp 4 (tmm: 0) 10.20.0.9:30984 10.20.1.103:8 10.20.0.9:11335 10.20.1.103:8 icmp 5 (tmm: 0) 108.86.114.132:4500 172.16.1.10:4500 108.86.114.132:51339 10.20.1.103:4500 udp 0 (tmm: 3) 10.20.0.9:33176 10.20.1.101:8 10.20.0.9:33176 10.20.1.101:8 icmp 6 (tmm: 0) 10.20.0.9:39349 10.20.1.102:8 10.20.0.9:9783 10.20.1.102:8 icmp 4 (tmm: 1) 99.88.254.242:4500 172.16.1.10:4500 99.88.254.242:4500 10.20.1.101:4500 udp 3 (tmm: 0) 10.20.0.9:21928 10.20.1.104:8 10.20.0.9:21928 10.20.1.104:8 icmp 9 (tmm: 0) 10.20.0.9:51093 10.20.1.102:8 10.20.0.9:1810 10.20.1.102:8 icmp 11 (tmm: 1) Total records returned: 27 - What_Lies_Bene1
Thanks. Looks like a bug to me. I've done a search;
http://support.f5.com/kb/en-us/solutions/public/14000/000/sol14061.html < doesn't seem to be this issue but it suggests there are issues with this version.
Not related to the issue but beware this one: http://support.f5.com/kb/en-us/solutions/public/14000/300/sol14398.html.
Is upgrading an option?
- KernelPanic
Yes, upgrading is an options,Is there a recommendation for a stable release?
