Leonardo_39231's avatar
Leonardo_39231
Jul 15, 2013
IP::idle_timeout Issue
I have a "IP::idle_timeout" setting of 1800 seconds that I apply to traffic when the Host header starts with the word "server". The problem is that some of the traffic gets the 1800 seconds timeout and some of it doesn't(defaults to 300 seconds). I've applied logging in the irule to see the before and after idle setting which shows it should be set to 1800 seconds but when I look at the connection table it only has the default idle setting of 300 seconds. Anyone see an error in my logic below?
viprion 2400 running BIG-IP 11.2.0 Build 2451.0 Hotfix HF1
ltm virtual /legacy/virtual_443 {
destination /legacy/10.1.1.1:443
ip-protocol tcp
mask 255.255.255.255
partition legacy
persist {
/legacy/persist_virtual_profile {
default yes
pool /legacy/virtual_7777
profiles {
http_redirect_rewrite_profile { }
tcp-lan-optimized {
context serverside
tcp-wan-optimized {
context clientside
wildcard_virtual_cert {
context clientside
rules {
/legacy/redirect_some_virtual_to_http_rule_3
header_insert_https_indicator
default_snat_rule
vlans-disabled
ltm rule /legacy/redirect_some_virtual_to_http_rule_3 {
partition legacy
set http_host [string tolower [HTTP::header "Host"]]
set http_uri [HTTP::uri]
if { $http_host starts_with "server" } {
IP::idle_timeout 1800
persist none
HTTP::header insert Secure-mode SSL
use pool virtual_8888
elseif { $http_uri starts_with "/config" or
$http_uri starts_with "/login" or
$http_uri starts_with "/ui" or
$http_uri starts_with "/utils" } {
use pool virtual_7777
else {
HTTP::redirect "http://$http_host$http_uri"
  • hoolio's avatar
    hoolio
    Can you post the default_snat_rule definition? I wonder if that SNAT iRule is forcing a 300 second idle timeout when SNAT is selected.
    Aaron
  • dlhace's avatar
    dlhace
    I ran into this same problem. I wanted to reset the idle_timeout only for certain things.
    I found the resolution in the documentation for IP::idle_timeout. https://devcentral.f5.com/wiki/iRules.IP__idle_timeout.ashx
    It appears that if you set idle timeout at the VIP level it set it for both client and server. But when I tried to set it in the irule I was only setting the client. The server needs to also be set so both sides are maintained.
