KenG's avatar
KenG
May 19, 2017
Inject commands on an FTP connection
Does anyone know if it is possible to inject a command into an FTP conversation?
I've trying to work around a bug in the application that is incorrectly asking for a transfer in ascii mode and prior to any GET I'd like to inject a BIN command. It looks like the server defaults to ASCII so I can't just remove the ASCII command from the stream so the [TCP::Payload] replacement thing doesn't seem appropriate.
Anyone got any bright ideas?
  • Anesh's avatar
    Anesh
    try the below
    when SERVER_CONNECTED {
    TCP::collect
    when SERVER_DATA {
    if {[TCP::payload] contains "string after which you want to inject BIN" }
    TCP::respond "BIN"
    TCP::payload replace 0 [TCP::payload length] ""
    TCP::release
