Tim_Arp_112576's avatar
Tim_Arp_112576
Aug 22, 2003
initial error with sample script LocalLBGlobal.pl
I'm trying to get setup with IControl using soap with perl on RH Linux. I have installed all the modules that I think I need but I get this error when I run LocalLBGlobal.pl
500 Can't locate object method "new" via package "LWP::Protocol::https::Socket" (perhaps you forgot to load "LWP::Protocol::https::Socket"?) at ./LocalLBGlobal.pl line 60
Any Ideas?
--Tim :?:
  • "I figured it out. I thought I had Crypt SSLeay but I did not.
    --Tim"
    Thanks,I met the same problem,I just installed Crypt:SSLeay from CPAN,ok now!
    :lol:
