Idle Timeout Settings in URL in LTM ?
Hi, 1. It appears that the timeout setting is very short. Is this on the LB side? For example if the user is on the support site and working on a page for a while, when the user go back to the main menu, he gets redirected to the login page instead. 2. We have applications that run EJBs.
Thanks and Regards Parveez
- rob_carr
Cirrocumulus
You haven't said how long a connection can be idle before a user experiences a redirection, but if it is only a few minutes, a likely suspect is the TCP profile timeout (The default timeout value is 300 seconds).
I'm not sure what role, if any, Enterprise Java Beans would play in this issue.
Hope that helps.
