Sajid's avatar
Sajid
6 years ago
https redirect issue with v14
After upgrading to v14 these irules mapped to https vs not working anymore.
 if { ( [string tolower [HTTP::host]] equals "www.abc.domain.com") } {
  HTTP::redirect "https://abc.domain.com[HTTP::uri]"
 if { ( [string tolower [HTTP::host]] equals "www.cbe.domain.com") } {
  HTTP::respond 301 Location "https://cde.domain.com[HTTP::uri]"
  • JG's avatar
    JG
    Any error messages in /var/log/ltm?
  • Sajid's avatar
    Sajid
    var/log/ltm
    Aug 9 14:06:00 lb_name err tmm[24290]: 01220001:3: TCL error: /Common/iRule_www_to_site <HTTP_REQUEST> - ERR_NOT_SUPPORTED (line 18) invoked from within "HTTP::host"
    • JG's avatar
      JG
      Will you be able to share the full original irule here? The coee you have posted has syntax errors and does not have 18 lines.
      • Sajid's avatar
        Sajid
         if { ( [string tolower [HTTP::host]] equals "www.abc.example.com") } {
          HTTP::redirect "https://abc.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.def.example.com") } {
          HTTP::respond 301 Location "https://def.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.ghi.example.com") } {
          HTTP::respond 301 Location "https://ghi.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.jkl.example.com") } {
          HTTP::respond 301 Location "https://jkl.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.mno.example.com") } {
          HTTP::respond 301 Location "https://mno.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.pqr.example.com") } {
          HTTP::respond 301 Location "https://pqr.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.stu.example.com") } {
          HTTP::respond 301 Location "https://stu.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.vwx.example.com") } {
          HTTP::respond 301 Location "https://vwx.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.yza.example.com") } {
          HTTP::respond 301 Location "https://yza.example.com[HTTP::uri]"
         if { ( [string tolower [HTTP::host]] equals "www.sas.example.com") } {
          HTTP::respond 301 Location "https://sas.example.com[HTTP::uri]"
  • The first one would be very easy to replace with a Local Traffic Policy...
  • Sajid's avatar
    Sajid
    This logic working for me.
     switch [HTTP::host] {
    "www.abc.example.com" {
    HTTP::respond 301 Location "https://abc.example.com[HTTP::uri]"
        log local0. "Sending request to abc.example.com"}
    "www.def.example.com" {
    log local0. "Request redirect to def.example.com"}
