HTTPS monitor does not work as expected.(what method does HTTPS monitor use to check pool member health)
Hi All,
I have a pool with two node which I am using HTTPS monitor to check node health. Monitor mark node down due to failed to receive expected string "OK". but I can use curl -k https:/xxx.xxx.xxx.xxx:8175/management/?action=health to get expected string. Can anyone help me to check what's wrong?
PS: F5 version(11.3.0)
ltm monitor https aw_https_monitor { cipherlist DEFAULT:+SHA:+3DES:+kEDH compatibility enabled defaults-from /Common/https destination : interval 5 partition Platform_Services recv OK send "GET /management/\?action=health\r\n" time-until-up 0 timeout 16 }
When I do a curl. I can get expected string "OK".
curl -vv -k * About to connect() to x.x.x.x port 8175 (0) * Trying x.x.x.x... connected * Connected to x.x.x.x (x.x.x.x) port 8175 (0) * successfully set certificate verify locations: * CAfile: /etc/pki/tls/certs/ca-bundle.crt CApath: none * SSLv3, TLS handshake, Client hello (1): * SSLv3, TLS handshake, Server hello (2): * SSLv3, TLS handshake, CERT (11): * SSLv3, TLS handshake, Server finished (14): * SSLv3, TLS handshake, Client key exchange (16): * SSLv3, TLS change cipher, Client hello (1): * SSLv3, TLS handshake, Finished (20): * SSLv3, TLS change cipher, Client hello (1): * SSLv3, TLS handshake, Finished (20): * SSL connection using AES128-SHA * Server certificate: * subject: C=Unknown; ST=Unknown; L=Unknown; O=localhost; OU=localhost; CN=localhost * start date: 2009-03-27 18:42:02 GMT * expire date: 2009-06-25 18:42:02 GMT * common name: localhost (does not match 'x.x.x.x') * issuer: C=Unknown; ST=Unknown; L=Unknown; O=localhost; OU=localhost; CN=localhost * SSL certificate verify result: self signed certificate (18), continuing anyway.
GET /management/?action=health HTTP/1.1 User-Agent: curl/7.19.7 (i686-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/0.9.8y zlib/1.2.3 libidn/0.6.5 Host: x.x.x.x:8175 Accept: /
< HTTP/1.1 200 OK < Content-Type: text/plain;charset=iso-8859-1 < Content-Length: 3 < OK * Connection 0 to host x.x.x.x left intact * Closing connection 0 * SSLv3, TLS alert, Client hello (1):
And I also used ssldump to read the package. It seems node doesn't answer client hello. here is the output of ssldump.
So, What method does F5 use for HTTPS monitor? and How deos HTTPS monitor works?
Hello,
In your monitor, you just send a request with an uri, that's it. When using curl, you have a set of headers automatically filled : host, User-Agent, etc.
maybe try to fil the following send option : GET /management/\?action=health 1.0\r\nHost: myhostname\r\nUser-Agent: curl/7.19.7\r\nConnection: Close\r\n
- Ellison_Zhang_2
Hi Yann, I tried you method. still no luck. you missed HTTP before 1.0\r\n. - Hi, You are right, i forget HTTP. Sorry for that. Maybe, there is a cipher issue on the monitor.
- Ellison_Zhang_2
Thanks Yann. I finally fixed this issue myself by changing the Cipher Suite to "AES128-SHA" instead of DEFAULT one.
- Yann_Desmarest_
Nacreous
Hello,
- Ellison_Zhang_2
Hi Yann, I tried you method. still no luck. you missed HTTP before 1.0\r\n. - Yann_Desmarest_
Nacreous
Hi, You are right, i forget HTTP. Sorry for that. Maybe, there is a cipher issue on the monitor. - Ellison_Zhang_2
