Ellison_Zhang_2
May 11, 2016HTTPS monitor does not work as expected.(what method does HTTPS monitor use to check pool member health)
Hi All,
I have a pool with two node which I am using HTTPS monitor to check node health. Monitor mark node down due to failed to receive expected string "OK". but I can use curl -k https:/xxx.xx...
Yann_Desmarest
Cirrus
May 11, 2016Hello,
In your monitor, you just send a request with an uri, that's it. When using curl, you have a set of headers automatically filled : host, User-Agent, etc.
maybe try to fil the following send option : GET /management/\?action=health 1.0\r\nHost: myhostname\r\nUser-Agent: curl/7.19.7\r\nConnection: Close\r\n
- Ellison_Zhang_2May 11, 2016
Hi Yann, I tried you method. still no luck. you missed HTTP before 1.0\r\n. - Yann_DesmarestMay 11, 2016
Cirrus
Hi, You are right, i forget HTTP. Sorry for that. Maybe, there is a cipher issue on the monitor. - Ellison_Zhang_2May 19, 2016
Thanks Yann. I finally fixed this issue myself by changing the Cipher Suite to "AES128-SHA" instead of DEFAULT one.
