Luis_Ribeiro's avatar
Luis_Ribeiro
Dec 19, 2017
HTTPS does not hit iRule
I'm to implement an iRule for HTTPS. The iRule is:
     HTTPS ------------------------------------------------------------------------
    log local0. ".TESTE HTTPS: [IP::client_addr] -> [IP::local_addr] HOST:[HTTP::host] PATH:[HTTP::path] [HTTP::uri] [TCP::local_port]"
    if { [string tolower [HTTP::host]] contains "xpto.com"  } {
        log local0. ".TESTE HTTPS.IF: [IP::client_addr] -> [IP::local_addr] [HTTP::host] [HTTP::uri] [TCP::local_port]"
        switch -glob [string tolower [HTTP::uri]] {
            "/index1.php"  {
        persist source_addr 255.255.255.255 1800
                log local0. ".TESTE index1: [IP::client_addr] -> [IP::local_addr] [HTTP::host] [HTTP::uri] [TCP::local_port]"
                node "10.1.144.100:[TCP::local_port]"
            "/index3.php"  {
                log local0. ".TESTE index2: [IP::client_addr] -> [IP::local_addr] [HTTP::host] [HTTP::uri] [TCP::local_port]"
                node "10.1.144.101:[TCP::local_port]"
            "/index3.php"  {
                log local0. ".TESTE /index3: [IP::client_addr] -> [IP::local_addr] [HTTP::host] [HTTP::uri] [`TCP::local_port]"
                node "10.1.144.102:[TCP::local_port]"
                log local0. ".TESTE index3: [IP::client_addr] -> [IP::local_addr] [HTTP::host] [HTTP::uri] [TCP::local_port]"
            default  {  HTTPS but not BKO
                log local0. ".TESTE DEFAULT: [IP::client_addr] -> [IP::local_addr]"
I have a similar iRule for a virtual-server HTTP and it works fine, this one, for https, does not work, and I do not see any log.
Later to check if the iRule is called I have added to the iRule:
 when CLIENT_ACCEPTED {
    log local0. ".TESTE CLIENT_ACCEPTED: [IP::client_addr] -> [IP::local_addr] [TCP::local_port]"
     Check the VS port to determine if connection is SSL or not
    switch [TCP::local_port] {
       "443" {
    log local0. ".TESTE CLIENT_ACCEPTED:443: [IP::client_addr] -> [IP::local_addr] [TCP::local_port]"
          set proto "https"
       default {
    log local0. ".TESTE CLIENT_ACCEPTED:not443: [IP::client_addr] -> [IP::local_addr] [TCP::local_port]"
          set proto "http"
I have logs for "CLIENT_ACCEPTED" and "443", so the iRule is called!
The https use TLSv3.
So the question is: what's wrong?
Thanks, LFR.
  • Do you have a client-ssl profile attached to the virtual server? You need to terminate the SSL connection if you want to see the HTTP traffic.
