https - cipher string
Can someone give me the correct syntax to make only this cipher work in the ssl negotiation?
SSLv3 (not TLSv1) using the (RC4-SHA group).TLS_RSA_WITH_RC4_128_SHA
Thank you,
- nitass
Employee
e.g.[root@ve11a:Active:Changes Pending] config tmm --clientciphers RC4+SHA+SSLv3+MEDIUM ID SUITE BITS PROT METHOD CIPHER MAC KEYX 0: 5 RC4-SHA 128 SSL3 Native RC4 SHA RSA [root@ve11a:Active:Changes Pending] config - John_Ogle_45372
Nitass,
This works just fine with a clientssl profile but I need it to work with a https monitor. I have tried a gazillion different variations with no success. I read in an older thread that bigd probably doesn't use the native TMM SSL stack. Do you know the correct syntax to use it with a https monitor?
Thank you, - drew_24552
Try the following:
DEFAULT:!ALL:RC4-SHA
Jason Rahm has a great series of articles on the SSL profiles. Check it out: https://devcentral.f5.com/tech-tips...her-suites
- John_Ogle_45372
Ok. I made a mistake. Two things:
1) After a reboot of the VE, I got the cipher Nitass posted to go right in. Wireshark shows that it still was using TLSv1.
2) After examing a capture of my working curl test again, it is using SSLv3 but this is the cipher string I need, please:
TLS_RSA_WITH_3DES_EDE_CBC_SHA
My apologies for the incorrect cipher string the first time.
Drew - I will read the article tomorrow. tired right now..) - nitass
Employee
TLS_RSA_WITH_3DES_EDE_CBC_SHA can you try this?[root@ve11a:Active:Changes Pending] config tmsh list ltm monitor https myhttps ltm monitor https myhttps { cipherlist DES-CBC3-SHA compatibility enabled defaults-from https destination *:* interval 5 send "GET /\\r\\n" time-until-up 0 timeout 16 } [root@ve11a:Active:Changes Pending] config ssldump -Aed -nni 0.0 host 200.200.200.101 and port 443 New TCP connection 1: 200.200.200.11(34552) <-> 200.200.200.101(443) 1 1 1373977265.0672 (0.0028) C>SV3.1(80) Handshake ClientHello Version 3.1 random[32]= 51 e5 3a b1 0e f7 75 f9 df 06 42 16 a8 bc 29 2c 32 08 9c 53 9b b9 3e 1a e1 31 c5 87 f2 58 50 0f resume [32]= f7 8b d5 52 45 60 65 3e 0e f9 39 d5 58 82 4b 1c 92 e0 93 7a f9 9e 49 21 1a 23 10 df 9d 4f ec c3 cipher suites TLS_RSA_WITH_3DES_EDE_CBC_SHA Unknown value 0xff compression methods unknown value NULL 1 2 1373977265.0690 (0.0018) S>CV3.1(81) Handshake ServerHello Version 3.1 random[32]= 51 e5 3a 03 0e 9c 42 f5 0c 4e 6b d1 48 88 d5 dc e9 17 c3 df 7e 8c 20 21 4e d7 5f 64 5f 80 44 16 session_id[32]= f7 8b d5 52 45 60 65 3e 0e f9 39 d5 58 82 4b 1c 92 e0 93 7a f9 9e 49 21 1a 23 10 df 9d 4f ec c3 cipherSuite TLS_RSA_WITH_3DES_EDE_CBC_SHA compressionMethod unknown value 1 3 1373977265.0690 (0.0000) S>CV3.1(1) ChangeCipherSpec 1 4 1373977265.0690 (0.0000) S>CV3.1(48) Handshake 1 5 1373977265.0707 (0.0016) C>SV3.1(1) ChangeCipherSpec 1 6 1373977265.0707 (0.0000) C>SV3.1(48) Handshake 1 7 1373977265.0707 (0.0000) C>SV3.1(40) application_data 1 8 1373977265.0732 (0.0025) S>CV3.1(104) application_data 1 9 1373977265.0732 (0.0000) S>CV3.1(32) Alert 1 1373977265.0732 (0.0000) S>C TCP FIN 1 10 1373977265.0742 (0.0009) C>SV3.1(32) Alert 1 1373977265.0745 (0.0003) C>S TCP FIN - John_Ogle_45372
Thank you! It looks like it is still failing. Please review the output of the working version using CURL and the failing https monitor. What could be different?
LTM https monitor - failing
New TCP connection 1: 172.16.31.8(37464) <-> X.X.X.X(443)
1 1 1373985585.6667 (0.0685) C>SV3.1(54) Handshake
ClientHello
Version 3.1
random[32]=
51 e5 5b 31 47 83 b8 47 59 fd 5c 96 35 c9 86 b4
9c b7 3c e0 bb 30 45 d5 ce 65 a6 95 60 37 11 ad
cipher suites
Unknown value 0xff
compression methods
unknown value
NULL
1 2 1373985585.7383 (0.0716) S>CV3.0(2) Alert
level fatal
value unexpected_message
1 3 1373985585.7383 (0.0000) S>CV3.0(2) Alert
level warning
value close_notify
1 1373985585.7383 (0.0000) S>C TCP FIN
1 1373985585.7391 (0.0007) C>S TCP RST
curl -kv3 https://hostname.company.com - SUCCESSFUL
New TCP connection 1: 172.16.31.8(37522) <-> X.X.X.X(443)
1 1 1373985669.4538 (0.0901) C>SV3.0(96) Handshake
ClientHello
Version 3.0
random[32]=
51 e5 5b 85 e5 10 f7 38 f9 1b 1d 1f cb cd 09 12
df bc 08 de 1a e1 1f b7 66 84 5e e3 03 e7 2b e4
cipher suites
SSL_DHE_RSA_WITH_AES_256_CBC_SHA
SSL_DHE_DSS_WITH_AES_256_CBC_SHA
SSL_RSA_WITH_AES_256_CBC_SHA
SSL_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA
SSL_DHE_DSS_WITH_CAMELLIA_256_CBC_SHA
SSL_RSA_WITH_CAMELLIA_256_CBC_SHA
SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA
SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA
SSL_RSA_WITH_3DES_EDE_CBC_SHA
SSL_DHE_RSA_WITH_AES_128_CBC_SHA
SSL_DHE_DSS_WITH_AES_128_CBC_SHA
SSL_RSA_WITH_AES_128_CBC_SHA
Unknown value 0x45
Unknown value 0x44
SSL_DHE_RSA_WITH_AES_128_CBC_SHA256
SSL_RSA_WITH_RC4_128_SHA
SSL_RSA_WITH_RC4_128_MD5
SSL_DHE_RSA_WITH_DES_CBC_SHA
SSL_DHE_DSS_WITH_DES_CBC_SHA
SSL_RSA_WITH_DES_CBC_SHA
SSL_DHE_RSA_EXPORT_WITH_DES40_CBC_SHA
SSL_DHE_DSS_EXPORT_WITH_DES40_CBC_SHA
SSL_RSA_EXPORT_WITH_DES40_CBC_SHA
SSL_RSA_EXPORT_WITH_RC2_CBC_40_MD5
SSL_RSA_EXPORT_WITH_RC4_40_MD5
Unknown value 0xff
compression methods
unknown value
NULL
1 2 1373985669.5154 (0.0615) S>CV3.0(42) Handshake
ServerHello
Version 3.0
random[32]=
51 e5 5b ab eb d1 e6 12 d7 01 60 d7 7a eb 64 7d
04 00 14 51 62 81 dc 41 9b 14 6a 0c 06 4b ad b8
session_id[0]=
cipherSuite SSL_RSA_WITH_3DES_EDE_CBC_SHA
compressionMethod NULL
1 3 1373985669.5727 (0.0573) S>CV3.0(3716) Handshake
Certificate
1 4 1373985669.5727 (0.0000) S>CV3.0(4) Handshake
ServerHelloDone
1 5 1373985669.5765 (0.0038) C>SV3.0(260) Handshake
ClientKeyExchange
EncryptedPreMasterSecret[256]=
9f 04 87 7e e0 a6 cb b9 9d 1e bd f7 d7 etc, etc
1 6 1373985669.5765 (0.0000) C>SV3.0(1) ChangeCipherSpec
1 7 1373985669.5765 (0.0000) C>SV3.0(64) Handshake
1 8 1373985669.6500 (0.0734) S>CV3.0(1) ChangeCipherSpec
1 9 1373985669.6507 (0.0007) S>CV3.0(64) Handshake
1 10 1373985669.6524 (0.0016) C>SV3.0(192) application_data
1 11 1373985669.7207 (0.0683) S>CV3.0(152) application_data
1 12 1373985669.7207 (0.0000) S>CV3.0(168) application_data
1 13 1373985669.7211 (0.0004) S>CV3.0(64) application_data
1 14 1373985669.7869 (0.0657) S>CV3.0(24) application_data
1 15 1373985669.7869 (0.0000) S>CV3.0(384) application_data
1 16 1373985669.7880 (0.0010) C>SV3.0(24) Alert
1 1373985669.7898 (0.0018) C>S TCP FIN
1 17 1373985669.8591 (0.0692) S>CV3.0(24) Alert
1 1373985669.8591 (0.0000) S>C TCP FIN - nitass
Employee
it seems bigd (health monitor) does not send sslv3 only even adding !tls1 in cipher list.
