slesh_219299's avatar
10 years ago
http to https redirection issue .
Hello guys I got fast question probably I have 2 vips : https with pool members : 443 http + i rule but someone attached there pool with members on port 80
when HTTP_REQUEST { HTTP::redirect https://[HTTP::host][HTTP::uri]
Customer was trying to connect via https vip but it was not working - from my experience it was nonsense so i removed pool http from http VIP and it started to work . I am not sure why , Vips were set with very standard options profile http and https + auto map
Thank you for replay in advance
  • Vik_K_236702's avatar
    Vik_K_236702
    Historic F5 Account
    Hi
    Your question is not clear. Can you elaborate a little on which VIP has what pool and irule is applied where ?
    Can you also give the exact irule , you using .
    Regards, Vikram (Vik)
  • nathe's avatar
    nathe
    Are you saying you've got 1 HTTPs vip with pool members listening on port 443, and 1 HTTP vip with a redirect irule and a pool with pool members listening on port 80? If so then the pool attached to the HTTP vip should not matter at all, a connection to this vip will simply get redirect to the https vip.
    I'd concentrate on the https vip. Are you offloading the SSL connection i.e. do you have a client ssl profile? Are you re-encrypting the SSL connection i.e. do you have a server ssl profile? If your pool members are on 443 then you either you need to both decrypt/re-encrypt or do neither. Also, if you do not have a clientssl profile then i would not add a http profile to the https vip - this does cause issues as the ltm can't see the http traffic as its encrypted.
    Hope this helps,
    N
    • nathe's avatar
      nathe
      yes, against the answer above.
