http monitor
Hello guys, I ma trying to set up a monitor http for every 5 min interval. get some file with response code. GET /check HTTP/1.0\r\n\r\n interval 299 sec timeout 301 sec. return string : live Can any one tell me how long the monitor will detect the site is down. How many queiers are sent to the server ever in a 20 min windows. When the response is not live , when will the server node be marked down. I see the default values as 5 to 16 interval. Does it mean i need to multiple the interval*3 +1 which makes 5 min interval to be 16 min. So does this mean F5 determines to make the node after after 16 min. Are my calculations and understanding correct.
- Chris_Grant
Employee
We recommend that you use a 3+1 interval timeout. Keep in mind, we keep sending monitors even when the system is down. A five minute interval is extremely long, but might make sense in your situation. Our default is a five second interval with a sixteen second timeout. In that situation (taking a simple SYN monitor), we would work as follows:
0 sec - SYN 5 sec - SYN 10 sec - SYN 15 sec - SYN 16 sec - we would mark the pool member down here 20 sec - SYN 25 sec - SYN 30 sec - SYN SYN/ACK ACK - we would mark the pool member up here, unless told otherwise by the config.If you had an HTTP monitor, there would just be more traffic, and with a 5 minute interval and sixteen minute timeout, we would send a monitor every five minutes and mark the pool member down after sixteen minutes of no response. You would still have only four monitor outstanding, however.
