AJ_6093's avatar
AJ_6093
Jan 15, 2009
HTTP monitor with Status code.
I want to create a HTTP monitor based on http status return code. What should I mention in the HTTP receive string, if I use “HTTP/1.0 200 OK” will it work. Also should I implement it on pool or on nodes?
Thanks & Regards,
AJ
  • It really depends on your requirements. If using the http monitor, you can send a query to special page that will give you a "we're good" message that tests more than just the root index, or if that's sufficient, you can implement an http monitor that pretty much just tells you the app is responding, not that it's good. You can also do the negative, where it marks the node/pool member down if the string is received.
  • If you are monitoring the pool members I don't see much benefit in monitoring the nodes separately. If it's down in the pool its status as a node doesn't really make any difference, and you're just duplicating health checks and causing more load on the node if you do that.
    Denny
  • hoolio's avatar
    hoolio
    Assuming the pool member responds to the send string with an HTTP 200 status, using a receive string of "200 OK" should work fine:
    curl -I www.yahoo.com
    HTTP/1.1 200 OK
    Date: Tue, 20 Jan 2009 15:14:39 GMT
    P3P: policyref="http://info.yahoo.com/w3c/p3p.xml", CP="CAO DSP COR CUR ADM DEV TAI PSA PSD IVAi IVDi CONi TELo OTPi OUR DELi SAMi OTRi UNRi PUBi IND PHY ONL UNI PUR FIN COM NAV INT DEM CNT STA POL HEA PRE LOC GOV"
    Cache-Control: private
    Vary: User-Agent
    X-XRDS-Location: http://open.login.yahooapis.com/openid20/www.yahoo.com/xrds
    Last-Modified: Tue, 20 Jan 2009 15:02:20 GMT
    Accept-Ranges: bytes
    Content-Length: 9562
    Connection: close
    Content-Type: text/html; charset=utf-8
    Aaron
