RBS_79242's avatar
RBS_79242
Jan 29, 2014
HTTP Monitor with Authenticate NTLM failing
I am finding that my http monitor is closing the connection after receiving the WWW-Authenticate: Negotiate directive.
Sys::Version
Main Package
  Product  BIG-IP
  Version  11.2.1
  Build    807.0
  Edition  Hotfix HF1
  Date     Tue Oct  2 10:46:52 PDT 2012
Hotfix List
ID397981  ID395272  ID397435  ID397882
ltm monitor http crm-test.dev.internal_80_http_monitor {
    app-service /internal_nonprod/crm-test.dev.internal_80.app/crm-test.wd.govt.nz_80
    defaults-from /Common/http
    destination *:*
    interval 30
    partition internal_dev
    password secret
    recv "200 OK"
    send "GET /F5Dynamics/main.aspx HTTP/1.1\\r\\nUser-Agent: F5 Health-Check\\r\\nHost: crm-test.dev.internal\\r\\nAccept: */*"
    time-until-up 0
    timeout 91
    username [email protected]
~  ssldump -AedaH -nni 0.0 host 10.106.0.15
New TCP connection 1: 10.228.128.10(32944) <-> 10.106.0.15(80)
1391050874.5897 (0.0026)  C>S
User-Agent: F5 Health-Check/4.0
Accept: */*
Authorization: Basic c3ZjX0Y1YWNjZXNzQGRldi5hZC5pbnRlcm5hbDp1lkRW9OUVZqV3VCUHdwbnhPdHFPM0s=
1391050874.5927 (0.0030)  S>C
HTTP/1.1 401 Unauthorized
Cache-Control: private
Transfer-Encoding: chunked
Content-Type: text/plain
Server: Microsoft-IIS/7.5
X-AspNet-Version: 4.0.30319
Set-Cookie: ReqClientId=6e803adf-3636-451b-9a6f-9550316e6f71; expires=Wed, 30-Jan-2064 03:01:14 GMT; path=/; HttpOnly
WWW-Authenticate: NTLM
X-Powered-By: ASP.NET
Date: Thu, 30 Jan 2014 03:01:14 GMT
31
HTTP Error 401 - Unauthorized: Access is denied
1391050874.5928 (0.0000)  S>C
0
This behavior is very different to that displayed in this post: https://devcentral.f5.com/questions?pid=8446
It seems that the F5 is ignoring the request to Authenticate and does not attempt to try the NTLM protocol after the IIS Server has responded with a auth failure.
Thanks.
    • RBS_79242's avatar
      RBS_79242
      Hi, thanks for the reply. I have tried making the username "dev\\svc_F5access" the result is the same. I have also tried adding a "\r\n" to the send string. The result is the same in both cases. FWIW, curl works with both usernames using --any-auth and --ntlm
  • Hi,
    But have you tried removing the domain name?
    I had exactly the same problem last week see my post below. Mike solved this by asking me to remove the domain name from the username field.
    https://devcentral.f5.com/questions/custom-http-health-monitor-failing-when-using-ntlm-authentication
    Cheers,
    Dave
      RBS_79242
      Thanks - I have tried removing the domain - this has not changed the situation. The F5 still fails to send NTLM auth headers after receiving the NEGOTIATE directive.
  • mikeshimkus_111's avatar
    mikeshimkus_111
    Historic F5 Account
    RBS,
    Can you post the monitor string as it appears in the LTM GUI? Different versions of BIG-IP append \r\n differently when the monitor configuration is saved in tmsh.
    thanks
      RBS_79242
      Hi, thanks for your reply. A TCPDUMP shows that a "\r\n" is being correctly inserted ONCE between the "Accept */*" and "Authorization" when the packet goes out on the wire. Here is an excerpt from a tcpdump -X 0x0090: 6f76 742e 6e7a 0d0a 4163 6365 7074 3a20 ovt.nz..Accept:. 0x00a0: 2a2f 2a0d 0a41 7574 686f 7269 7a61 7469 */*..Authorizati
    mikeshimkus_111
    Historic F5 Account
    You may want to open a case with F5 support on this. The only problems I've seen with NTLM HTTP monitors are with the username and line endings. Yours seem to be correct.
  • Hamish's avatar
    Hamish
    You're missing a '\n' at the end of the send string (When using no auth, you need two of them. When you're using auth, you need two. But you have none after the 'Accept: /'
    H
  • Hi Hamish,
    When the HealthCheck is set to:
    send "GET /F5Dynamics/main.aspx HTTP/1.1\\r\\nUser-Agent: F5 Health-Check\\r\\nHost: crm-testdev.internal\\r\\nAccept: */*"
    TCPDump shows a single \r\n being inserted by the F5 HealthCheck.
        0x0080:  726d 2d74 6573 742e 6465 762e 696e 7465  rm-test.dev.inte
        0x0090:  726e 616c 0d0a 4163 6365 7074 3a20 2a2f  rnal..Accept:.*/
        0x00a0:  2a0d 0a41 7574 686f 7269 7a61 7469 6f6e  *..Authorization
        0x00b0:  3a20 4261 7369 6320 5a47 5632 5848 4e32  :.Basic.ZGV2XHN2
    When the Health Check is set to:
    send "GET /F5Dynamics/main.aspx HTTP/1.1\\r\\nUser-Agent: F5 Health-Check\\r\\nHost: crm-testdev.internal\\r\\nAccept: */*\\r\\n"
    tcpdump still shows a single \r\n being inserted
    Now comes the interesting part! When the HealthCheck is set to:
      send "GET /F5Dynamics/main.aspx HTTP/1.1\\r\\nUser-Agent: F5 Health-Check\\r\\nHost: crm-test.dev.internal\\r\\nAccept: */*\\r\\n\\r\\n"
    TCPDump has this (which is not good)
        0x00a0:  2a0d 0a0d 0a41 7574 686f 7269 7a61 7469  *....Authorizati
        0x00b0:  6f6e 3a20 4261 7369 6320 5a47 5632 5848  on:.Basic.ZGV2XH
    But now the F5 actually sends an NTLM Request! But the end node closes the connection because of the malformed HTTP Auth request. So SSLDump looks like this:
    New TCP connection 1: 10.228.128.10(55320) <-> 10.106.0.15(80)
    1391124364.9248 (0.0036)  C>S
    Accept: */*
    Authorization: Basic ZGV2XHN2Y19GNWFjY2Vzczp1cmlkRW9OUVZqV3VCUHdwbnhPdHFPM0s=
    1391124364.9306 (0.0057)  S>C
    Set-Cookie: ReqClientId=1dac24c6-98a5-4649-bc8b-e036e08bfb54; expires=Wed, 30-Jan-2064 23:26:05 GMT; path=/; HttpOnly
    Date: Thu, 30 Jan 2014 23:26:04 GMT
    31
    1391124364.9306 (0.0000)  S>C
    0
    HTTP/1.1 400 Bad Request
    Content-Type: text/html; charset=us-ascii
    Server: Microsoft-HTTPAPI/2.0
    Connection: close
    Content-Length: 326
    Bad Request
    Bad Request - Invalid Verb
    HTTP Error 400. The request verb is invalid.
    1    1391124364.9306 (0.0000)  S>C  TCP FIN
    1391124364.9312 (0.0006)  C>S
    Accept: */*
    Authorization: NTLM TlRMTVNTUAABAAAAB4IIAAAAAAAAAAAAAAAAAAAAAAA=
    1    1391124364.9316 (0.0003)  C>S  TCP FIN
    So in conclusion behavior is the same for 0 or 1 trailing \r\n's when two \r\n's are set on the send string - the F5 actually tries to follow through with NTML Auth but the server disconnect because of the extra \r\n that is presented.
      mikeshimkus_111
      Historic F5 Account
      One thing you could try is to modify the the authentication providers in IIS so that NTLM is first in the list, instead of Negotiate. We've seen OneConnect have issues with that in the past, maybe your monitor is as well? F5Dynamics is the name of your CRM deployment? That's also the example we give in the deployment guide. thanks
