BJ_114988's avatar
BJ_114988
Mar 21, 2019
How to verify if mutual authentication is working or not ?
How to verify if mutual authentication is working or not ? i can see that there is openssl command to veriify it.
Can someone please explain more about it and give commands ?
  • @BJ, If i understand correctly you wanted to test client authentication right? If Yes, below syntax can help you..
        openssl s_client -connect : -key  -cert
    Cheers...
