How to validate receive string and set multiple send string
For one of the VIP below is the HTTP Send String I configured.
GET /portal/portaladmin/healthCheck HTTP/1.1\r\nHost: TEST.TEST.Ca\r\nConnection: Close\r\n\r\n
How to confirm what I am receiving in as receive string ? I need to set Receive String as 401. ? I used Curl and I see 401 is showed up ( marked Black ). So is it that I only need to write 401 in the Receive String of Monitor ?
2nd question I need to set multiple monitor for different services configured on same server. How to set multiple send string from a single Monitor Configuration. ? Let say if I am configuring 2 send string and 2 corresponding receive string how to set that when both of the String Condition need to be True as a condition to mark the VIP live. ?
[admin@F5:Active:In Sync] ~ # curl -vk https://test.test.ca/portal/portaladmin/healthCheck
* About to connect() to test.test.ca port 443 (#0)
* Trying 10.8.16.62... connected
* Connected to test.test.ca (10.8.16.62) port 443 (#0)
* successfully set certificate verify locations:
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSLv3, TLS handshake, Client hello (1):
* SSLv3, TLS handshake, Server hello (2):
* SSLv3, TLS handshake, CERT (11):
* SSLv3, TLS handshake, Server key exchange (12):
* SSLv3, TLS handshake, Server finished (14):
* SSLv3, TLS handshake, Client key exchange (16):
* SSLv3, TLS change cipher, Client hello (1):
* SSLv3, TLS handshake, Finished (20):
* SSL connection using DHE-RSA-AES256-GCM-SHA384
* Server certificate:
* subject: C=CA; ST=ns; L=Halifax; O=Nova Scotia Power Inc; OU=IT; CN=test.test.ca
* start date: 2019-04-17 00:00:00 GMT
* expire date: 2021-04-21 12:00:00 GMT
* subjectAltName: test.test.ca matched
* issuer: C=US; O=DigiCert Inc; CN=DigiCert SHA2 Secure Server CA
* SSL certificate verify ok.
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/1.0.1l zlib/1.2.3 libidn/1.18
> Host: test.test.ca
> Accept: */*
< HTTP/1.1 401 Unauthorized
< Content-Type: text/html
< Server: Microsoft-IIS/10.0
< WWW-Authenticate: Negotiate
< WWW-Authenticate: NTLM
< X-Powered-By: ASP.NET
< Date: Mon, 05 Aug 2019 18:41:27 GMT
< Connection: close
< Content-Length: 1293
< Vary: Accept-Encoding
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"/>
<title>401 - Unauthorized: Access is denied due to invalid credentials.</title>
<style type="text/css">
body{margin:0;font-size:.7em;font-family:Verdana, Arial, Helvetica, sans-serif;background:#EEEEEE;}
fieldset{padding:0 15px 10px 15px;}
h1{font-size:2.4em;margin:0;color:#FFF;}
h2{font-size:1.7em;margin:0;color:#CC0000;}
h3{font-size:1.2em;margin:10px 0 0 0;color:#000000;}
#header{width:96%;margin:0 0 0 0;padding:6px 2% 6px 2%;font-family:"trebuchet MS", Verdana, sans-serif;color:#FFF;
background-color:#555555;}
#content{margin:0 0 0 2%;position:relative;}
.content-container{background:#FFF;width:96%;margin-top:8px;padding:10px;position:relative;}
</style>
</head>
<body>
<div id="header"><h1>Server Error</h1></div>
<div id="content">
<div class="content-container"><fieldset>
<h2>401 - Unauthorized: Access is denied due to invalid credentials.</h2>
<h3>You do not have permission to view this directory or page using the credentials that you supplied.</h3>
</fieldset></div>
</div>
</body>
</html>
* Closing connection #0
* SSLv3, TLS alert, Client hello (1):
- Simon_Blakely
Employee
For your first question - yes, having the Receive String in the monitor set to 401 is appropriate.
Testing monitor strings with curl is the best approach to figuring out if the string is correct and viewing the response.
For your second question, you need to create and apply multiple monitors to your pool - you can set the pool to require all monitors being up to mark the service as up.
- Subrun
Thanks for your reply.
For multiple monitor is it possible to share technical details ? I mean configuration wise how it should be or any reference document ?
- Simon_Blakely
Employee
You just create your individual monitors for each target URL, and apply them to the pool.
Or maybe I misunderstand your question.
- Subrun
Oh I see. I have not understood you are saying to create multiple monitor and call at the pool.
I think you understood my question. I was actually thinking i need to write all the ( send , receive string ) in a single monitor but I think you gave me right direction.
Will post here once I create multiple monitor and call to the single Pool and share the status. 👦
