How to use v11.4.1 CPM to achieve redirection and source address control
i have a request from customer example as below 1.) when user access to www.test.com forward to specific pool member 1.1.1.1 2.) when user access through http://www.test.com or https://www.test.com will redirect to https://www.test.com/ebilling 3.) Block user access from 10.10.10.10 source ip address.
I not able to find deny , block or allow option from CPM policies , is we can achieve to control source IP from CPM ? else i may need write a full irule for above 3 objective.
please advice
- What_Lies_Bene1
You're correct. You can achieve 1) and 2) with CPM. 3) Will require an irule or packet filter (or rule if you're using AFM).
See here for some details on how it can be done: https://devcentral.f5.com/questions/can-i-block-an-ip-address
