Devarsh_371978's avatar
Devarsh_371978
Oct 03, 2018
How to understand, already installed SSL certificates are used where & how..?
Hi All,
There are couple of SSL certificates installed on my F5 Box. This certificates are going to expire next month. so how to identify where & how those certificates are being used & if i need to renew them or not.
Thank You in Advanced.
Dev
  • The simple answer is you need to look at all the Client and Server SSL Profiles configured on the F5 BIG-IP and see if the cert/key is configured to be used.
    However, this is not as easy as it sounds and many people have worked on solutions to map SSL profiles to certs and keys.
    A solution I did on the command line can be found in the answer to this question here: Reporting : Virtual Server - SSL Certificate Mapping
  • THi's avatar
    THi
    You can see the certificates with their expiry info in the GUI
    System  ››  Certificate Management : Traffic Certificate Management : SSL Certificate List
    The GUI does not show where the certificates are being used, but you can extract that info with command line/tmsh:
     tmsh list ltm profile client-ssl recursive cert-key-chain
    This gives you a list of certificate config items in the client-ssl profiles.
    ltm profile client-ssl clientssl {
        cert-key-chain {
            default {
                app-service none
                cert default.crt
                chain none
                key default.key
                passphrase none
  • Hello,
    Here is another way to see which CERT's have a VIP assigned to them. (VER: 12.1.2)
    Step 1. Navigate to the "System" tab File Management / SSL Certificate List
    Step 2. Find and choose SSL Cert in question
    Step 3. Click on the "Instance" Tab
    Step 4. This will show you the VIP the SSL CERT is pointing to.
    • Sukesh123456's avatar
      Sukesh123456
      Hi Devarsh,
      Did you find an answer to this thread ? You can find the ssl profile first and then locate the VIP if that is also a need.
      So go to the CLI and search for ssl profile first
      list ltm profile client-ssl | grep -i -B 10 certname
      list ltm profile server-ssl | grep -i -B 10 certname
      Now once you find the ssl profile you can find virtual server also similarly.
