How to POST data to specific page after APM authentication?
Is there a way to POST data gathered during authentication to specific web page.
- using SAML federation to to authenticate the user and to get extra info (like e-mail address)
- the application is IIS based and uses local shared credentials to sign in with NTLM SSO
- the application needs the extra info POSTed to specific page as user information and for it to create the app session
SAML federation/attribute extraction to APM session variables is ok. Similarly NTLM SSO works. Question is how do the POSTing of the data after the auth? POST form/data are in the body (content/payload), not in headers, nor as parameters. Do I need to use iRule for this, which event?
- Amit_Karnik_269
Do you need the data to be sent via POST only ? If so then you would need an iRule. Add the General Purpose - iRule Event to your policy with a name lets say "Event1"
Now add an iRule to your virtual server for Event1 and then use SIDEBAND to POST out your data.
when CLIENT_ACCEPTED { ACCESS::restrict_irule_events disable } when ACCESS_POLICY_AGENT_EVENT { if { [ACCESS::policy agent_id] == "Event1" } { SIDEBAND::connect -destination .... SIDEBAND::send "POST ..... " } }If you are just trying this to log data, instead of POST you could use the policy General Purpose - Logging to send out data to a remote log server.
