Robert_47833
Altostratus
Aug 17, 2011how to match string1?string2?
there is a string start with /cjj?cjj2,how to match it?
if{
$uri matches_regex "^/cjj?cjj2"
{ persist none
HTTP::redirect "http://www.stubhub.com/404.html"
does "?" can be matched in matches_regex?
or do we have other method to achieve this?
- Kevin_Davies_40
Nacreous
if { $uri starts_with {/cjj?cjj2} } { { ... rest of code } }
Kevin (Jarvil) - Robert_47833
Altostratus
If I insist on using match_regex,
$uri match_regex "^/cjj?cjj2"
does it work? - Kevin_Davies_40
Nacreous
Sure if you put a \ in front of the ? otherwise it represents any non-whitespace character. Its worth noting that any regex matching is significantly slower that's why there are many alternatives.
Kevin (Jarvil)
