Johanna_162707's avatar
Johanna_162707
Aug 09, 2017
How to maintain connections in a secondary node when main node fails
I have a VS with a pool of two servers, that only sends traffic to one of the servers, because I had configured in the pool the option "Priority Group Activation" in 1, and I also had set each node in a "Priority Group". The node A is set with "Priority Group" 2, and Node B is set with "Priority Group" 1. This is wotking well, the traffic is sent to Node A always unless this node becomes unavailable, in which case traffic is sent to node B. However, when node A becomes available all the connections are resumed to node A, but I need the traffic to stay in node B until I manually make the change.
  • nathe's avatar
    nathe
    Johanna, what about configuring Manual Resume on the health monitor? That way once node A comes available it won't resume traffic duties until you explicitly enable the pool member.
    Alternatively, doesnt persistence help here as this will take priority over priority group settings.
    N
