charlie_14972's avatar
charlie_14972
Jun 22, 2011
How to loadblance Oracle DB by use irules to differentiate read and write request?
I want to use irules to differentiate oracle read and write request.
Who can tell me how to do it?
rule:
If request include "select" ,then use db_read_pool
else then use db_write_pool
I can not know what is the right syntax.pls help me,thanks.
Charlie
  • Hi Charlie,
    There is a post similar to your request made in the Oracle Forum
    http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/63/aft/2929/showtab/groupforums/Default.aspx
    I hope this helps
    Bhattman
  • hoolio's avatar
    hoolio
    I don't think the logic is quite that easy though, as you could have a DDL command with a select statement:
    SELECT *
    INTO new_table
    FROM old_table
    If this is something you'd like to see built into LTM, you could open a case with F5 Support with details on your use case.
    Aaron
  • Hi Bhattman,
    That irule cause can not connect to the database
    Hi Hoolio,
    Thank you for your suggestions
    Charlie
  • hi Charlie,
    The iRule won't know how to connect to the database - simply because the irule is looking into the TCP packet. However, that would lead into a more sophisticated version of the Irule to account for the DDL command.
    Bhattman
