How to identify Edge Client and redirect to different hostname?
Hi, we have deployed Edge Client service on the same virtual server that is used for webtop (a relic of SSL VPN via the webtop). I'm now finding that the access policy between the two is diverging, and also that there seems to be some strange behaviour where one is logged into both at the same time because they share the same access policy. I would like to separate them out into their own virtual servers.
Has anyone done this before? What was your migration plan? I am hoping for a way where I can configure a redirection of some kind without having to update all the users (some of which are external and would need to be updated by hand).
Thanks,
Evan
- Seth_Cooper
Employee
There is a "Client Type" action in the VPE. My suggestion would be to add in the VPE for the webtop policy a check for the edge client and if found then use the redirect ending type and redirect to the SSLVPN VS. You could also add a client type to the SSLVPN VS and if using the browser redirect to the webtop VS.
-Seth
