Mahmoud_Eldeeb_
Dec 16, 2014how to hide a part from url on client side?
how to hide a full url from client side like (abc.com/xxdgg/ddeeff/fffgg/eertdsd/eee....) to be like abc.com/finance. for ltm running ver 11.5
- Michael_Jenkins
I think the only way to really do this would be to use a STREAM profile to replace your original string (
) with the desired string (abc.com/xxdgg/ddeeff/fffgg/eertdsd/eee
) in the response. Then you need to update the request matching hostabc.com/finance
and uri matchingabc.com
and set the URI tofinance
(using/xxdgg/ddeeff/fffgg/eertdsd/eee
) and setting the host toHTTP::uri "/xxdgg/ddeeff/fffgg/eertdsd/eee"
if it needs to be changed (usingabc.com
)HTTP::host "abc.com"
