Wyko
Altostratus
4 years agoHow to get a monitor from a pool through REST API or Python SDK?
I have a simple challenge: Given a pool, find its associated monitor. The problem is that the query for a monitor requires the monitor type. LTM pools don't carry info on the kind of monitor they use, only the partition and name of the monitor. I could theoretically iterate through all possible types of monitors there are, but what is the correct way to do it?
