Robert_47833's avatar
Robert_47833
Dec 06, 2011
how to gather how many IPs hit the url and how many times
Hi,dear irule
I meet a new requirement recently
there is an URL: http://cjj.cjj.com/select
I wanna gather the stats :
how many IPs hit this url: such as ,10.0.0.1 ;10.0.0.2;10.0.0.3
how many times per each ip hit this as 10.0.0.1 10 times
10.0.0.2 200times
10.0.0.3 1times
how to achieve this
thanks very much
  • the period may be one month ,it is only the current stats,I need a long term stats
    thanks in advance
  • have you seen table command article by Spark? there are good counting examples there.
    v10.1 - The table Command - Counting by Spark
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=2381
  • hmm,I am not sure whether table command will reslove this
    Need to know how many IPs and how many times per Ip hit the url
  • hoolio's avatar
    hoolio
    Hi Jucao,
    I'd actually suggest using High Speed Logging to send a syslog message to a remote (pool of) syslog server(s) and then do your parsing there off of LTM. This will save CPU and memory on LTM. For details on this, see this recent post:
    Log unique Client Addresses per (Hour|Day|Etc)
    http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/aff/5/afv/topic/aft/1184658/afc/1258376/Default.aspx
    Aaron
  • Hamish's avatar
    Hamish
    Yes. You can use the tables. But be aware that although the tables are good, keeping stats in there for a month is probably overkill. And you don't need to.
    What Id' suggest is a balance between using tables and using HSL (Or SIDEBAND connections) to update an external server with the stats. SImilar to the method I used in the LDAP stats counting and reporting iRUles.
    H
  • this is counted for 60 seconds. please feel free to revise.
    [root@ve1023:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@ve1023:Active] config  b rule myrule list
    rule myrule {
       when CLIENT_ACCEPTED {
            table set -subtable "iplist" [IP::client_addr] "ignored"
            set reqno [table incr "reqs:[IP::client_addr]"]
            table set -subtable "reqrate:[IP::client_addr]" $reqno "ignored" indefinite 60
            if {[string tolower [HTTP::uri]] equals "/stats"} {
                    set stats "ip,request number\n"
                    foreach ip [table keys -subtable "iplist"] {
                            append stats "$ip,[table keys -count -subtable "reqrate:$ip"]\n"
                    HTTP::respond 200 Content $stats
    [root@ve1023:Active] config  curl -i http://172.28.19.79/stats
    HTTP/1.0 200 OK
    Server: BigIP
    Connection: Keep-Alive
    Content-Length: 67
    ip,request number
    172.28.19.80,12
    192.168.181.16,5
    172.28.19.253,2
