How to enable TCL 8.5.x for iRules on 12.x
According to SOL36322151 TCL Version 8.5 seems to be supported since 12.x.
So how do I enable it for use in iRules?
If I try to use some of the new features (e.g. "dict" or "switch -regexp -matchvar...") in the iRules editor, it still gives me the same errors when saving as if it still used the old TCL 8.4 version.
I am running BIG-IP 12.1.1 Build 0.0.184
Regards,
Marc
- stan_piron
Cumulonimbus
In the SOL36322151, new supported commands are listed. dict is listed as non supported command even if this is a new command in tcl 8.5.
there is no way to enable it.
- stan_piron
Cumulonimbus
you can open a support case for this.
but in your code, I do not see why you need externalpath.
and, when using matchvar in tcl, the value is a list of match. the first match is :
[lindex $externalpath 1]instead of matchvar, you can use:
regsub -nocase "/extpath/" [HTTP::path] $internalpath newuri HTTP::uri $newurianother thing. ".*$" does not make sense. it search any character from match string to the end of the uri.
you should set regex : {^(/extpath/)} instead of {^(/extpath/).*$}
