How to enable proper remote logging for irule
Hello All,
We have created irule to unblock the Geo-location for few IP address. But we are facing the challenge with remote logging.
We have used ASM_REQUEST_DONE in irule. It means ASM already processed the request and generated the log in the back end the same log is forwarded to remote logging server as well.. But it's false positive.. We want to send unblocking log to remote syslog server as well.. Please help us on this.
Thank you.
- S_L_V_Ramana_T
Hi Blakely,
Thank you for the response.
The issue has been resolved with help of BIG IP logs.
Thanks & Regards
Ramana T
- Simon_Blakely
Employee
When logging from ASM using a user-defined format string, there is a field "blocking_exception_reason" that will display "Unblocked from iRule" when ASM::unblock is used.
