Deepak123_16590
Aug 06, 2014how to do simple redirection using iRule
Hello,
I have a site www.myserver.com which is not registered with SSL. But I have a certificate for https://myserver.com. Can anyone help putting an iRule where when user access www.myserver.com it redirect to https://myserver.com ?
Much appreciate
- Kevin_Davies_40
Nacreous
when HTTP_REQUEST { if {[HTTP::host] eq "www.myserver.com"} { HTTP::redirect "https://myserver.com[HTTP::uri]" } } - Deepak123_16590
Thanks Kevin :)
- Kevin_Davies_40
Nacreous
Don't forget to tick the left of the post that provided the answer for you. This provides recognition to the volunteers help others on this site.
