janlaw_195243
Nov 26, 2015How to disable weak cipher for management port.
Hi all,
I was told that there are some findings after some scanning at my management port ip(x.x.x.x:443) for my Load balancer and i need to disable it.
Is there any solution to disable weak cipher for the management port? i need to disable CBC ,static RSA key exchange and TLS 1.0
I am using F5 big ip ltm 4000s. Version 11.6.4
Thanks.
- nathe
Cirrocumulus
Janlaw, this askf5 solution should help:
https://support.f5.com/kb/en-us/solutions/public/13000/400/sol13405.html
N
