hu_127869
Oct 31, 2006Historic F5 Account
how to delete an existing connection by iRule ?
Hi All:
Is there any command that able to delete an existing connection by iRule ? May I have a sample code if we support this feature ? Thanks
- hoolio
I'd think you could use HTTP::close or TCP::close if you were executing a rule on the existing connection. I don't think there is a way to access the connection table and delete connections that are not related to the connection that the rule is being triggered for. I'm speculating though...
