andrewmjones
Apr 28, 2018How to delete a persistence entry in a partition in cli
I'm looking how to delete a persistence entry but it is located in a partition. I can see the entry when in the correct partition on the GUI but not when I run tmsh show ltm persistence persist-records
- oguzy
Hi andrewmjones,
After you run tmsh, you should change directory for partition.
cd /partition_nameThen you can delete any records using the following command. Just keep in mind you may need route domain id when you try to delete certain records.
delete ltm persistence persist-records
