Jonas_Karlsson1
Feb 09, 2005Historic F5 Account
How to controll in what order rules are evaluated?
I'm looking for a way to control in what order iRules are evaluated.
I have a number of small code pieces, all of them using the same event, that I would like to use in various combinations on different virtual servers. It would be much neater to specify in what order they should be evaluated when I assign them to the VS instead of combining those I need to one huge rule.
Think I have seen something like this once but can't find it when I need it.
Cheers
Jonas
- Joe_Hsy_45207
I know this is an old thread, but it was very helpful to me. FYI, the priorities are 0 to 1000 not 1 to 1000. Also, it seems that there is actually 3 levels:
- priority of the event (defined with each When block)
- priority of the iRule itself (when created via iControl)
Also, through experimentation, it looks like the priority of the iRules within a virtual server is changed when you use the UI to change the ordering.
//Joe - Mark_A_Ayers_15
When more than one iRule is configured on the virtual you can do this
user@(ltm_name)(...)(tmos) ltm virtual user@(ltm_name)(...)(tmos.ltm.virtual) list target_virtual_name rules ltm virtual target_virtual_name { rules { irule_name_1 ... irule_name_2 irule_name_n } } user@(ltm_name)(...)(tmos.ltm.virtual) modify target_virtual_name rules { irule_name_1 irule_name_2 ... irule_name_n }I show the list so that you can review the current order.
