fbozkur1_138329
Nov 22, 2013how to configure x forwarded for WAS
I have two WAS 6.1 servers which are behind F5. I want to see the originating source IP from the WAs servers. How could I see the source IP?
Thanks, regards,
- Kevin_Stewart
Employee
You could very simply enable Insert X-Forwarded-For option in the HTTP profile, or use an iRule:
when HTTP_REQUEST { HTTP::header replace X-Forwarded-For [IP::client_addr] } - fbozkur1_138329
Thanks Kevin, Should I do anything on WAS side?
